Question about Briggs & Stratton Garden
Carburetor Fuel Issue, To Rich fuel load, Black Smoke. I have a John Deere riding lawn mower LA 115, 3 years old. Briggs and Strattion 19.5 hp, Model #31P677, Qode type # 0132 B1070531ZD, Nikki carb. with #'s 792345,G02802 and 6131C on it. Replaced with new - Key switch, Starter solenoid, Carburetor rebuild kit / all O rings, needle & float. Soaked / Cleaned Carb. Blew out all points with air pressure (jet, too). Did Not remove jet. Clear jet and vents. Float works correctly. Throttle and choke connections, settings correct. STILL SMOKING, just a little better than what it was. Research said, might be exaust valve seat or build up. Removed valves, cleaned, polished head, valves and seats. Valves lashed to .004. Note, exaust valve was very loose at disassembly. Everything looks very good with no obvious problems. New spark plug and compression is right on specks. I don't now what else I can do. I can hold the engine throttling bar (don't know what its name is, sorry) from automaticaly jumping back and forth and it will run great for a minute. I can also crimp the fuel line off and shortly after that it will run great for about 20 seconds. Sorry for so long but, I need you to know what I have done in detail. If anyone can help it would be greatly appreciated. Thank You, Shawn
2 Suggested Answers
4x4papa
  • 14 Answers
SOURCE: Briggs Flo Jet carb floods and puts gas into the crankcase
This is a common problem. The needle and seat are prone to being held open from debris, old fuel (these days it only takes a month for fuel to start to go bad) and poor mower design. The weight of the fuel from the tank can be enough to overpower the float system with just the slightest "gumming" of the needle seat. Also, if it's equipped with an electrically powered valve on the bottom of the float bowl, this unit can outright fail, get gummed up a bit, or the electrical system have a problem and power is getting to this unit while switched off, leaving it open thus passing fuel. Most likely, replacing the needle and seat, giving the carb a good cleaning will solve your problem, however if there is damage to the seat from age or debris, just install a 2 dollar in line shut off valve available at most retailers. Then just turn the fuel on and off manually. Cheap fix. 2. Drain the oil from the engine, refill with new oil and just a oz. of atf (automatic trans fluid). Crank the engine with plug wire disconnected for 30 sec or so, then connect the plug wire. Start the engine, but only let it run near idle for a minute or so. Drain again, letting the crankcase "air out" with all plugs\dipstick removed. Remaining fuel will evaporate. Refill and your off and cutting......The ATF is a detergent of a type and will help to collect the fuel from the surfaces inside the engine. It's important to note the fuel will have washed any lubrication properties from the oil, and damage to the journals and other surfaces can happen if the engine is run too long. Usually following the above procedure will limit damage and the engine should be good for many more seasons. Good luck! Papa
Posted on Nov 15, 2008
D110 briggs and stration engine 19.5 hp gas coming out exhaust pipe, also air filter
Your engine is getting too much gas ...soo much it's passing the rings. This is a total carburetor issue. What is happening is that from starting it over and over again, it's building uproducts more and more... the fuel inlet needle isn't closing enough to cut off the fuel.
2 options...
Get a new carburetor
Rebuild the old one
Also use carburetor cleaner, gum out, spray into the plug hole then reinstall the plug...don't use starter fluid...
Nov 04, 2015 | John Deere Garden
John deere d105 auto
It floats?? but the carburetor still leaks fuel ????
Fuel is HIGHLY COMBUSTIBLE! Please read the safety notes in your owners manual before attemting this repair. Lawn Mower Carburetor Repair Small Engine Maintenance Briggs Stratton
Apr 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere L108.drives for about 2 minutes mowing and stops.leave for about 15 mins and will go again.puffs of smoke when put under load
John:
The puffs of smoke when you put the machine under a load make me think that your carburetor is loading up and needs to be adjusted. Adjust the fuel/air adjustment screws on the carb until it runs properly.
Jan 20, 2013 | John Deere Garden
John deere ride on problems
Black smoke indicates rich mixture. Dirty air filter. choke stuck on. loose main jet in carby. just a few possibilities.
Dec 31, 2012 | Oregon Scientific Oregon Gator Mulcher 3N1...
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
John deere 115 riding mower miss-fires and shoots black smoke out of exhaust pipe plus won't throttle up.
Sounds like it is running too rich. Check to see if the choke at the front of the carburetor is closed. It is possible that the cable came off the choke lever. If that is not the case. while the engine is running, pinch off the fuel pump hose for about a minute. If it is a rich running problem, the engine will clear up as it runs out of gas, then it will die. If it clears up momentarily, check or have someone else check the float level in the carburetor. The float may have sunk (has a hole in it) and is causing rich running.
Feb 15, 2011 | Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
La 135 won't start
If it was black smoke, then you're getting too much fuel in the system, which could be a lot of different things...air intake restriction, float in the carb, choke cable, etc.
Sep 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Riding lawn mower won't start
The carburetor is clogged from old fuel. remove and clean and consider getting a carb kit to give it new seals and gaskets and needle/seat. Sta-bil in the fuel, particularly over winter will prevent this problem. When the work is done, be sure to drain the old fuel and use fresh.
Jun 25, 2009 | Garden
Garden Logo
550 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
