Question about Saeco Cappuccinatore Kit White
I have a Saeco Royal Coffee Bar ,Cappuccinatore doesn't draw milk
I have a Saeco Royal Coffee Bar and the machine works perfectly with the exception of the Cappuccinatore attachment. When I switch to Cappuccinatore there is lots of steam generated but it does not draw any milk. I have fiddled with the little valve on the Cappuccinatore but have had no success in getting it to draw milk. Is there a trick to it or is my Cappuccinatore defective?
3 Suggested Answers
SOURCE: saeco cappuccinatore
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Posted on Jul 06, 2008
SOURCE: saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Posted on Oct 01, 2008
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
How can I make the milk hotter using the cappuccinator?
Yes you can make a small trick for that. You can use a sqweeter on the milk silicone hose so the milk can flow with more dificalty as long as you can see milk flowing this can be up to 78 C . You should keep the cappuccinatore very clean since you will need the steam to come as easy as possible
Feb 04, 2010 | Saeco Royal Professional Espresso Machine
Cappuccinatore does not draw milk
Hi
There should be a little knob on top of the cappuccinatore. It is what causes the milk to flow up the tube. When it is steaming, rotate the knob slowly until the milk starts to flow up the tube. You can fine tune the knob to get the best foam.
If you are missing the pin that has the knob on it, there will be a small hole in the outside top of the cappuccinatore. If you don't have hole and a knob, it is broken off and you need to replace the cappuccinatore
Oct 19, 2009 | Saeco Royal Professional Espresso Machine
I am looking for a replacement cappuccinatore automatic milk pin
check out the enclosed link:
http://www.cafeparts.com/SearchProducts.asp
Let me know if this helps.
Have a great day!
Mar 06, 2009 | Saeco Royal Professional Espresso Machine
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Saeco Cappuccinatore Kit White Logo
122 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
