Question about Lowrance HDS-8 GPS Receiver
Fitting power antenna to HDS8
Wire diagram please
  • 560 Answers
Hi. Please click here for the installation instruction.
Let me know if you need further assistance. Thanks.
Posted on Jun 01, 2010
  • 2 more comments
  • tamobbs Jun 02, 2010
    thank you i have this book , it dont show antenner leads or power connection with T pieces supplied in kit
    thank you but donot show wireing for kit with T PIECES AS SUPPLIED IN ANTENNER BOX CAN YOU HELP !
  • Liza Halbrook
    Liza Halbrook Jun 02, 2010
    Hi. Please take a picture of that T connector and post it here. Thanks.
    please cancel my subscription to fixya and refund i shall goto my suppler
Lowrance gps problems
The device may need updating,
They were a similar issue with tomtom and the units needed a simple update to allow them to find the GPS.
http://www.ssgames.co.uk/
http://www.hometurnedpens.co.uk/
Jul 31, 2014 | Lowrance Insight USA HDS8
ERROR 37.0 DUCATI
Immobilizer and transponder
The Immobilizer allows the vehicle to be started only if the rider uses the special ignition key which sends the identification code to a decoder fitted into the instrument panel. The emitting - receiving system is made of a "TRANSPONDER" fitted into the ignition key heads and an antenna close to the ignition lock.
Transponder keys
The two keys contain the secret master code for programming the immobilizer system and allowing engine start is stored into this key;
Transponder is included into the key head and consists of a power supply circuit, a ROM (Read-Only Memory) and a transmission circuit. The Transponder is power supplied through the magnetic field generated by the antenna which is enabled as soon as the instrument panel is switched on. As it is very compact and needs no outer power supply through a battery, it is directly fitted into the key head.
Warning
Circuits into the key head are not shockproof.
Immobilizer antenna
The antenna consists of a plastic-coated copper coil connected to wires ending up with a connector.
The antenna (A) is fitted onto the ignition lock into its specially designed seat.
Operating principle of the immobilizer
When the ignition key is positioned to ON, the decoder into the instrument panel energises the antenna, which generates an electromagnetic field power-supplying the key transponder. The Transponder sends the code stored into its ROM, which is received by the antenna and sent to the decoder. Here the secret code is matched with a second code. If this comparison proves successful, engine starting is enabled.
Immobilizer warning lights and indications
When the ignition key is turned to OFF, the immobilizer inhibits engine operation. When the ignition key is turned back to ON to start the engine, the following happens:
1) if the code is recognised, the immobilizer enables engine starting. Press the START button (2), to start the engine;
2) if the diagnostic light (8) comes on and the page with the message "Error IMMO" is displayed when you press button (1) in position B "t", it means that the code was not recognised. When this is the case, turn the ignition key back to OFF and then to ON again. If the engine still does not start, try with the other black key. If the other key does not work out either, contact the DUCATI Service network.
Caution
When programming the immobilizer as described below, use only the required key and keep the other keys away otherwise they might interfere.
Removing the immobilizer
Turn the ignition switch to OFF.
Disconnect Immobilizer antenna connector (21).
Note
Reference (21) is the same that is indicated in the diagrams under "Arrangement of wiring on frame", Sect. P 1.
Remove the immobilizer antenna wire ties.
Loosen screws (1) securing Immobilizer antenna protection to ignition switch.
Remove the cover (2) and the Immobilizer antenna (3) clear of the key-operated switch.
Refitting the immobilizer
Apply a drop of Loctite inside cover (2).
Locate antenna (3) to cover (2), and secure it in place with the two pegs (A) of the cover.
Fit the cover on the key-operated switch, easing the antenna wire downwards.
Tighten the cover starting screws (1) in their thread.
Tighten the screws to the specified torque (Sect. C 3, Frame torque settings).
__________________
Jan 22, 2013 | 2003 Ducati 999
Wiring diagram for instalation
install what? but crutchfied can give you free step by step diagrams, also check out modified-life-logo.gif.com
May 02, 2010 | Car Audio & Video
Wiring Diagram for CDX-FM687
red is swiched ignition yellow is constant power and the sound is transmitted to the antenna. re small box with antenna in and out
Feb 04, 2010 | Pioneer CDX-FM687 6-Disc CD Changer
I recently bought a 2005 toyota corolla verso(irish model) is there any way i could get my hands on the audio wiring diagram because i want to fit a parrot bluetooth handsfree kit
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
rate pls
Dec 10, 2008 | 2005 Toyota Corolla
2004 Chevy Tahoe stereo wiring diagram
BLACK-ground
RED-accessorie
YELLOW-power 12v
PURPLE-left rear
GREEN-right rear
WHITE-left front
GREY-right front
BLUE-REMOTE
and the other blue one is for remote antenna..
Dec 04, 2008 | 2004 Chevrolet Tahoe
97 4Runner broken antenna; want to replace it with non-power antenna
You will just need to get a antenna that will fit your vehicle try a local stereo shop and wire it in.
Aug 22, 2008 | 1997 Toyota 4Runner
I need a wiring diagram
to what car is it being fitted?
standard stereo wireing is as follows:
SPEAKERS
+White -White/black Front left
+Grey -Grey/black Front right
+Green -Green/black Rear left
+Purple -Purple/black Rear right
POWER
+12v Con Yellow
+12v Ign Red
+12v Antenna Blue
-12v Return Black
Tele mute brown
Illumination Orange
Hope this helps somewhat.
Dec 22, 2007 | Car Audio & Video
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Lowrance HDS-8 GPS Receiver Logo
66 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
