Fan motor goes off and on - Heating & Cooling
The unit comes on with cold air and in aminute or two shuts off and e1 comes on .the unit has worked fine and this problem just happened. don't know what e1 means
Posted on Jun 01, 2010
I HAVE A BRYANT 662CJ030-A THE FAN MOTOR IS NOT WORKING THE PUMP COMES ON IS THERE A REPLACEMENT MOTOR FOR THE FAN?
yes there should be a replacement fan motor you can order online, but most of the time it's the capacitor that goes out not the fan motor. you can test the capacitor or just replace it and see what happens. .
Aug 11, 2014 | Heating & Cooling
I have a central air condition carrier ,the problem is when the air condition staret the compresor staret but motor fan not I have to out side n push the blade then the motor star workign ,well I replace...
The capacitor starts the motor The capacitor has three terminals C common goes to the contactor HERM to the S terminal on the compressor brown wire with a white stripe from the fan motor goes to FAN
Aug 01, 2014 | Carrier Heating & Cooling
Blower comes on then stops running
You may need to replace the fan motor but before you do check and make sure you don't have a loose wire going to the fan motor. You might be loosing power to the fan motor. Is the fan motor making noise before it stops. Chev are famous for having the bearing on the fan motor going out and the fan will clatter against the fan motor housing. If you need to change the motor just remove the wire to the motor and pull the beauty cover off then you can remove the holding screws and put your new motor in. Be sure to remove the battery cable to ensure you don't short something out during the process and burn the wiring.
Apr 15, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Remove rv fan motor
Probably not. You need to get a puller on the fan blades though
Jun 03, 2013 | Coleman Heating & Cooling
I have a holmes desk fan i need to know how to wire the moter uip
Check the ohm reading across pairs of wires.
Buy cheap multimeter at home world, install battery, set to read ohms : upside down horseshoe is ohms.
You have a non reversing 110volt motor.
One pair of wires goes goes to start winding, for starting the motor spinning, and these wires will have higher ohm reading.
Other pair of wires goes to run winding, that keeps fan at motor speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/Color-codewire2.html
Oct 02, 2012 | Holmes Products Dryers
Fan outside isn't running and when turned on the unit outside is running very loud.
The fan outside keeps your compressor cool, the compressor, if left running without the fan running to cool it down can get damaged, the fan normally gets its power from a switch box located outside or near
it. or the motor on the fan could have just gone bad. the fan motor is not as expensive as the compressor to replace. its easy to replace. sometimes what goes out 1st on these motors is the capacitor,the capacitor stores enough voltage to give the motor that extra push to turn. many times its just the capacitor that goes out. when you purchase a motor make sure you also get the matching capacitor.if you can turn the fan and it starts running, its the capacitor, if it starts running and has any kind of bearing noise then you will have to replace the motor. good luck!
Aug 08, 2011 | Heating & Cooling
Connecting protect condenser fan motor 5 wire to dual capacitor. old fan motor has 3 wires. which wires go where?
Wiring a fan motor to a dual capacitor, the leads with the stake on's go to the fan and common.
Usually the brown with white strip goes to the middle or "C" terminal and the plain brown goes to the fan or "F" terminal the other three are power and usually use the black and red connected to the fan relay.
Jun 13, 2011 | Ruud UAKA037 Air Conditioner
Fan comes on but will not blow cold air
This fan has a blower motor which will eventually fail.
The fan will still oscillate , but the blower motor will burn out. The motor thermal fuse will fail , lower bearing failure and armature burn out. No replacement motor less than fan price so, when it goes buy a better longer lasting fan.
Sep 30, 2010 | Lasko 2515 Tower Fan
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
