Question about Estate EED4300TQ Electric Dryer
No power Hi, When I press the On switch nothing happens. I have power all the way to the machine (terminal block where the cable joins the machine). There are signs of arcing on one of the prongs of the plug. Ideas? Thanks, Ian
  • Estate Master
  • 43,501 Answers
There can be many reasons why your dryerNo power - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 04, 2010
No power to Miele W404 Plus washing machine.
hi
it could be faulty flex cable from the washer to wall socket or where the flex cable is screwed into the terminal block inside the machine come out or broken
Dec 21, 2017 | Miele Washing Machines
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
Not getting power to the starter
that happens
what work has been done on the car recently
check battery cable to starter is sound
tight battery terminals
if starter motor clicks ..flat battery
if starter wont turn at all
possible faulty starter
or immobilizer is still activated
Oct 14, 2016 | Cars & Trucks
2003 f150 4x4 dont work. No light. Nothing is happening
Hi.
Make sure that the battery cables are making contact. Use a volt meter and check if there is power across the battery terminals. Check the ground connection from battery to the engine block. Check that there is power to the main distribution box, located under the hood. In the distribution box check the PCM relays. After that check the fuse box inside the vehicle.
Sep 25, 2013 | Ford F-150 Cars & Trucks
I have several Motorola GM1200E radios,all with the same fault.They will not switch on.When the power button is pressed and held briefly,nothing happens.(not a power supply problem as i have other GM1
Hi Charlie,
Do not give up, may I suggest you join: yahoo group specific to your radios Make/Model, there you will receive info as well as being able to download manuals, schematics and other goodies.
I hope this info is of use to you.
Regards,
Peter
Feb 07, 2013 | Radio Communications
Sometimes middle of process, it suddenly stop. and i try to trun off and press start button again, but nothing happen.normally if i press start and it shows green light but it didn'nt. it seems start...
IT SEEMS TO ME LIKE THIS SWITCH HAS WEAK CONTACTS
OR WEAK TERMINALS .
THE SIMPLE CASE IS USING SMALL PLAYER AND TO SURE THE TERMINALS IN GOOD CONDITIONS
Jun 18, 2009 | AEG Washing Machines
Dryer has power won't start cycle Hi - The light goes on inside the dryer, but when I close the door and select start nothing happens.
If that doesn't do it, (door switch), then check underneath the top and look for the thermal overload switch. Bypass it and see if it runs. If not, then start back at the wiring at the receptacle and then follow to the terminal block located in the back of the dryer. You could be getting power to the receptacle but it may stop there because of a loose wire. You could have lost a leg of power.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Power comes on but nothing happens
hi
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.
Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailed
here. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.
Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Nov 21, 2008 | Washing Machines
Compaq 5000 Series Desktop
Everythings Fixable. If you locate the power switch Cable To Motherboard. Should be marked ( pwr on Motherboard )
use a hard-drive jumper. small plastic link block. to join the 2 connections on the board itself. ( Jumper )
now plug the mains cable in, if it runs. then you know it,s the switch thats faulty. you can replace this with any similar make break switch. alternatively. if the case has a seperate reset switch. use that instead.
Mike @ Compurepair.
Jul 22, 2008 | Compaq Presario 5000 PC Desktop
Estate EED4300TQ Electric Dryer Logo
205 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
