Question about Dell Microsoft Windows XP Home Edition
I forgot my Administrator Password
Until now I was the only user in my computer and I didn't need to use any password, but I remember that I did store one for the admin when I installed windows XP. My roommate asked me to use my computer and after he messed up one of my files I decided to add another user and to block the access to some of the folders. Everything went great and I created the User, changed the folders setting and the way you login to my computer. When I did restart I have 2 users, but I forgot the admin password and I can't login with my user only the new user I created. I can't change anything because the new user have limited access. I can't believe I did something so stupid, please help I am desperate. I recenlty bought all of the belongings in a persons house as they were moving out due to a husbands loss. I got everything and sold it on e-bay in yard sales etc.. but my daughter had ben nagging me for a computer and lucky enough that was one of the things I now owned. I turned on the computer and tried to log in but the husbands password was not given to me, the poor family was half way on the other side of the world. Now I have no way to ge on that computer without the password. Help me I don't want to but her a new computer if there's a perfectly good one right there. Whats the trick to get the password.
  • 1 more comment
  • Anonymous Jun 16, 2008
    I have a problem to open my computer. Because I forgot the administrator passward. would you help me
  • Woine Jun 16, 2008
    I have a problem with another computer. The problem was to open the computer because of forget the administrator passward. would you help me.
  • docope55 Aug 10, 2008
    forgot my password
    Sergeant:
  • 202 Answers
Hi jessymessy
There's a registry tweak for Windows XP that adds a 2nd Control Panel Users applet. W/ this tweak, you can manage/change/set the passwords of any user on the system - including the Admistrator - by using this Control Panel applet.
Go HERE
Look at the top-most item in the right-hand column.
Click (on the left side a bit) of this listing.
If you are not familiar w/ editing your registry, STOP! If you'd like, you can give me your email address and I'll email the tweak to you already set. (You can click on my ASK ME button if you'd rather not post it here.)
If you have me send you the tweak, all you'll have to do is right-click on it and choose MERGE. This will make the requisite changes in the registry.
After you've set all the passwords to your liking, you might want to REMOVE this Control Panel applet so no one else has access to it. There are other ways to hide it w/in other user profiles but this is the least complicated.
Instructions for removing the applet are on a link to the right of the same listing - click on the word REMOVE.
The same applies, I can create this tweak for you, too and you can apply it the same way.
I'll look around to see if I can find a VBS script, etc of this tweak that you can run.
If the information I provided you w/
resolved your problem or lead you
to a resolution for your problem or
an answer to your question, then, a
"FixYa" rating would be most
appreciated. @:)
(You can assign the same rating
to more than one expert who
participated in solving your problem.)
It is best to wait until the problem has
been resolved b4 rating the experts'
solution(s). Once you enter a rating,
the problem will be closed and we will
not be able to continue to assist you.
Very often it will take more than one
exchange of information between you
and an expert in order to resolve your
problem. If a proposed solution doesn't
work for you, don't rate it yet. Instead,
post back here letting us know and we'll
continue to work w/ you until we find a
solution that does work for you.
Thank you
BJ @:)
Posted on Apr 09, 2008
  • 3 more comments
  • B Joan Rapier
    B Joan Rapier Apr 09, 2008
    This registry tweak works in both Windows XP Professional and Windows XP Home. I use it myself as an IT support specialist on both operating systems.
    Once the "User Accounts 2" Control Panel applet registry tweak is merged into the registry, reboot (restart) your computer then log into one of the Administrator accounts on your computer.
    -->> Click on START
    -->> Click on CONTROL PANEL
    -->> Click on USER ACCOUNTS 2
    -->> Double-click on USER ACCOUNTS 2
    -->> The applet will open to the USERS tab.
    -->> Highlight the ADMINISTRATOR user
    -->> Click on the RESET PASSWORD button in the lower right of the tab.
    -->> Type in the new password (or leave it blank if you want no password on that account)
    -->> Type in the new password again in the field below the top one.
    -->> Click the OK button.
    -->> Click OK again to exit USER ACCOUNTS 2
    -->> Restart your computer and enter the ADMINISTRATOR profile w/ the credentials (password) you just created
    -->> (If yours is Windows XP Home Ed, you will only be able to enter the Administrator profile in SAFE MODE)
    -->> Please, let us know if you would like assistance w/ this.
    Don't hesitate to ask for assistance w/ any of these instructions, etc.
    BJ @:)
  • B Joan Rapier
    OK. I just don't feel comfortable settin' you loose on your system registry. If somethin' goes wrong during that process, it could be a "bad thang".
    So, to that end, here's a much simpler - albeit a wee bit shady ;) - process:
    * The upward pointing carat (^) indicates a space.
    (01) Click on the START button
    (02) Click on RUN (lower right column)
    (03) Type verbatim (w/out the brackets): [ cmd ]
    The window will open up w/ the following path: C:\Documents^and^Settings\[YOURUSERPROFILE]
    (04) Type verbatim (w/out the brackets): [net^user^Administrator^*]
    (05) Hit ENTER
    (06) Type in the password you'd like to set for the account (the cursor will not advance while you are typing)
    (07) Hit ENTER
    (08) Type in the password again to confirm (again, the cursor will not advance)
    (09) Hit ENTER
    (10) Click the [X] in the upper right-hand corner of the COMMAND window.
    (11) Log out of the current user account and log in to the Administrator account w/ the new password.
    If you don't want a password assigned for a given user, just skip steps (6) & (8)
    You can use this tecnique for resetting or changing the password for any user on the system.
    This works on both Windows XP Professional and on Windows XP Home Ed.
    If RUN is missing from your START MENU, just let me know and I'll tell you how to get it there.
    ** Lordy, I hope the hack police don't come get me!! :o
    BJ @:)
  • B Joan Rapier
    If the RUN command is missing from your START MENU:
    (01) Click on START
    (02) Click on ALL PROGRAMS
    (03) Click on ACCESSORIES
    (04) Click on the COMMAND PROMPT shortcut
    Then begin w/ step (03) of my previous post
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 11, 2008
    Hello jessymessy
    How did it go?? Did you get your password restored? Gain access to the Administrator profile?
    If we were able to solve your password delimma, please, remember to rate the experts' solutions. If you would like more assistance on this topic, just let us know. We are more than happy to help.
    Thank you,
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello Jessy,
    How did it go? Did the information and links I provided you w/ enable you to reset the users' passwords (including the Administrator password) OK?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
  • 295 Answers
When you forgot your Administrator password and want to reset it (without being able to logon to Windows that is), just follow these instructions: http://pubs.logicalexpressions.com/pub0009/LPMArticle.asp?ID=305
Posted on Mar 23, 2009
    Sergeant:
    Champion:
  • 277 Answers
When you in a log in process try to press (control alt del) twice..
in the username type administrator if you remember your password type it..if not just enter... you need a administrator access to reset all username password.....
if not works, you need to reinstalled your os...
Administration pasword forget
Posted on Mar 09, 2009
F yo mama
Posted on Feb 20, 2009
Can't log in to toshiba c660d
Why can't you remember the password? Did you set the password? Is it your laptop or is it stolen?
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen user Logon Password?
Which Operating System Windows XP? Windows Vista? Windows 7?
You type like an honest person so lets see if we can help you out :)
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
May 02, 2012 | Toshiba Computers & Internet
Tip
What is the Windows XP Administrator Password?
<p>Windows XP, the most popular versions of Windows, was widely installed by PC users. Do you remember after you installing your first copy of Windows XP, how long did it require you to realize that you didn't know the administrator password? I vaguely remembered that it was about a week before I needed to make some changes in the file system. It suddenly came to me to be logged on as an administrator, but I do not know the password of the administrator! <br /> <p> <br /> <p><img src="windows-xp-administrator-password.jpg" /> <p><br /> Luckily, Windows XP (both Home and Professional versions) have a "hidden" administrator account which is autogenerate when install. This account usually doesn't show up on the logon screen and most people are totally unaware of its existence. Usually it is ok because we didn't need to user this account very often, only when we don't know the administrator password, need access to the Windows XP recovery console or boot into Windows XP safe mode, the default <b>Windows XP administrator password</b> would come in handy.<br /> <p><br /> What is the Default Administrator Password in Windows XP?</b><br /> <p><br /> Knowing the default password of Windows XP administrator account would be very useful.<br /> <ol> <li>Try to leave the password blank. Simply press Enter without typing anything.</li></ol> <p>The default Windows XP Administrator password is defined to blank during the initial Windows XP installation process.<br /> <ol> <li> Enter the password for your account. It often depend on how Windows XP has been installed on your computer and what part of XP is asking for an admin password, the main user account will also be configured with administrator privilege.</li></ol> <p><br /> I Forgot my Windows XP Administrator Password!</b><br /> <p><br /> Windows XP User Accounts applet in the Control Panel functions is to create a password reset disk wizard. Using this wizard, a floppy disk or USB flash drive can be used to create a specific password reset disk for specific user account on a specific Windows XP computer. The password reset disk can only be used with the computer it was created on and it can also be reused to reset the account's password multiple times. However, you need to know the password of the account you want to create the reset disk for, and you must create the reset disk before you forget the administrator password <br /> Here is how to <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">reset XP administrator password</a> with the XP password reset disk:<br /> <ol> <li>Insert the XP password reset disk to the computer</li> <li>Click the Use your password reset disk item on the XP logon screen to start the Password Reset Wizard. Click the Next button</li> <li>Follow the instructions to create a new password. </li> <li>Logon with the new password.</li></ol> <p><br /> I Didn't Create a Password Reset Disk!</b><br /> <p><br /> OK, if you <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgot Windows XP administrator password</a> and don't have a password rest disk, you won't be able to create a password reset disk anymore. Instead, there are several things you can try to get access to your windows. <b>SmartKey Windows Password Recovery</b> is your ticket. This password recovery tool not only works on Windows XP, but also on all releases of Windows NT/2000/Vista/ 7 and Windows Server 2003/2008. It works by booting from a CD/DVD or USB flash drive and reset the <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten Windows XP administrator password</a>.<br /> <p><br /> <b>NOTE: </b>If you change the administrator password on a Windows XP or Windows Vista system with the Encrypted File System (EFS), all of the encrypted files will become inaccessible. The password for the Administrator account is used to create the EFS encryption key. Changing the Administrator account back to using the original password should restore access to the encrypted files, but I have never tried it.<br /> <p> <br /> <p>If you only need to blank the <b>Windows XP Administrator password</b>, here are the basic steps:<br /> <ol> <li> Download and install SmartKey Windows Password Recovery software.</li> <li> Burn the software to CD/DVD or USB flash drive. </li> <li> Insert newly created CD/DVD and reboot your computer from the CD/DVD or USB flash drive </li> <li> Reset the forgotten Windows XP password, remove the CD/DVD or USB flash drive and then reboot the computer</li></ol> <p>Having the capability to reset <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten XP administrator passwords</a> and regain access to a locked computer can be a great time saver, but should only be tried by an IT professional. you may probably make things worse rather than better if you use sophisticated system or manipulation tools<br /> <p><br /> <p>Article Source:<a href="http://recoverlostpassword.com/article/windows-xp-administrator-password.html">http://recoverlostpassword.com/article/windows-xp-administrator-password.html</a><br />
on Apr 15, 2011 | Computers & Internet
How do I rest my ASUS LAPTOP if I do not remember the password
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 22, 2012 | ASUS Computers & Internet
Forgot my password
Its a bit of a read
Passwords add a level of security to your computer. When sharing a computer with others, your customized settings, computer programs, and system resources are more secure when you assign a password to your logon name or user account name. The steps to perform this task differ depending on whether your computer is a member of a network domain or is part of a workgroup (or is a stand-alone computer). My computer is on a domain You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure. Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password. My computer is not on a domain If no password has been assigned to the user's account, a password will need to be created before it can be changed. For information about creating a password, click Related Topics. The steps to perform this task differ depending on the type of user account you have. If you have a computer administrator account Open User Accounts in Control Panel. Click your account name. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type your new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. If you have a limited account Open User Accounts in Control Panel. Click Change my password. In Type your current password, type your current password. In Type a new password and Type the new password again to confirm, type the new password. You can also enter descriptive or meaningful text in Type a word or phrase to use as a password hint to help you remember your password. Click Change Password. Notes A user with a computer administrator account can create and change passwords for all users on the computer. Users with limited accounts can create and change their own passwords, as well as create their own password hints. If a user with a computer administrator account changes the password for another user, that user will lose all EFS-encrypted files, personal certificates, and stored passwords for Web sites or network resources. Notes To open User Accounts, click Start, click Control Panel, and then click User Accounts. For more information about user accounts, click Related Topics. Related Topics
hope this helps
Nov 27, 2010 | Computers & Internet
I forgot my password to my computer and now i can not log in
By removing password on WINDOWS LOG-I, here a tip on how to remove the password.
# Before the windows system boot up press F8 then will appear Windows Configuration command then select SAFE MODE.
# Wait until it comes up to the screen and you will see the 2 USERS "ADMINISTRATOR" in "USERNAME".
# Go to Control Panel and select USER ACCOUNT.
# Click on "USERNAME" then remove the password.
# Restart your COMPUTER and the windows system will direct you to the DESKTOP.
Hope this might help you my instructions. Good luck!
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
try to format the c-drive and install the windows again
Dec 03, 2008 | Audio Players & Recorders
you should be able to contact dell support and they should have you on file. when you first bought the computer and logged on the web you had to register your computer. dell should have this information on file, also because each windows program has a register number they might also have you on file. i would try this and it should solve the problem.. please rate this and also please reply back if it doesn't get solved..thanks
Sep 04, 2008 | Microsoft Windows XP Professional With...
Try this only if u hav Windows Xp
On the welcome screen
PRES CTRL-ALT-DEL thrice or untill welcome screen changes to fast user switching screen.
Enter user name as "administrator" and leave password blank
if the above doesnot work also enter password as "administrator" this time .
If u succeed u hav admin rights and u can now againg delete add any user .
Aug 26, 2008 | Microsoft Windows 2000 Professional for PC
When I forgot my XP administrator password, Windows Password Recovery Tool 3.0 will help us reset password efficiently by creating a password reset disk!
May 09, 2008 | Computers & Internet
Computers & Internet Logo
366 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
