Question about Cell Phones
InterTel Encore CX desk phone was locked up on "initializing" . Tried power on and off. used to help. Not now. Replaced phone with another. Same problem. What now? This is a church. Service techs are expensive. Hopefully you guys can help me through this.
  • 713 Answers
Hi,i think the phone needs to be reprogrammed entirely,the problem is from the operating memory,this does'nt cost more than 20-25 dollars to fix,i won't support the idea of you doing it yourself because reprogramming involves great skill and technique.
Thanks and take care
Posted on Jun 01, 2010
  • 1 more comment
  • Judith Kadela Jun 01, 2010
    Thanks but everyone in Detroit that I have dealt with has a minumum service call fee starting at $125. but if it has to be reprogramed looks like I don't have a choice.
  • Oyelade Gbenga Jun 01, 2010
    I'm sorry about that but it depends on the discretion of the technician,probably,you might have to negotiate greatly,but the solution is to reprogram the phone.
    Thanks and good luck
    I don't think it's the phone. Since I posted the problem here is what has taken place.
    I swapped out the "initializing" phone with a brand new one. Same problem. The new phone is now locked up on Initializing.
    I swapped out another phone that was developing a lot of static with the one that was locked up on initializing. it works good - no static either.
    So it's not the phone. Any other suggestions or should I put this question back out there?
Admin changes on encore cx
You can actually do the system programing thru the phone itself, press the prog button above the display on the phone & go to system programing, you'll need the system admin code (try 1111).
Alternatively you can install a programing applicatrion on your pc & connect to the async port on the main control unit. The program applicaion would have been delivered with the system docs.
Mar 05, 2009 | Inter-Tel Encore Phone
Speaker phone indicator will not go off
Liooks like you have the phone programmed to "Handsfree answerback" this will cause the handsfree light to flash continiously.
In this mode the phone will auto answer any internal call from another extension.... so watch out.
To switch this mode off press the program button above the displey & you be given th option to switch "Auto Answer off " I think it's the first option, try it.
Jan 07, 2009 | Inter-Tel Encore Phone
Intertel GLX phone rings busy unless unplugged
You could have a bad phone try to swap it with a working one. If that does not work there could be a problem with the port in the system or cabling. Move to a new port or new cable
Jan 05, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
I need my phone to ring at my desk
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
Dec 30, 2008 | Inter-Tel Intertel 6123300 GLX Executive...
Inter-tel 660.300 Intertel Premier 24 Button
Line could be dead from local provider (Verizon,etc.).Could be a bad port on the phone system. Maybe a bad connection into phone system. What Intertel system do you have?
Oct 16, 2008 | Inter-Tel 660.3000 Intertel Premier 24...
Intertel phone system died
Look for power on the InterTel system, any kind of lights on the system is an indication you at least have power to the system. If you are plugged into a power strip and have no lights, remove the power cord from the strip and plug it directly into an AC outlet. Be sure to turn off the system before plugging it into a wall outlet, and then turn the system back on. Good Luck
Aug 03, 2008 | Inter-Tel ECX 1000 Telephone
Intertel Encore CX - phones will not initialize and cannot connect via MPS software
There are 3 capacitors on the the mother board that blow. You need to completely disassemble the unit down to the main board. The main board in held in place by 3 screws, then needs to slide to the left to free it from the case. Carefully pry it to the left using a flat blade screwdriver.
The capacitors are underrated for this board, and I use a capacitor with a higher voltage rating to replace them. You can get these from Radio Shack, P/N 272-1030, 470uF 35V.
The ones that usually blow are the 3 on the bottom left of the main board. They are in a vertical row, and you can see that the top of the capacitors "puff" and have a little dome on top of the capacitor.
Replace the capacitors, and reassemble. The 35V rated ones are just a little bigger and you may not be able to push them down to the board all the way, but no worries, it will fix your problem. We are a dealer for this product and found that every one that we install, failed with the same problem.
I should mention that there is another capacitor just to the right of these 3 that may also fail. Again, look for the top of the capacitor. If it is not perfectly flat, change it.
Jun 18, 2008 | Inter-Tel Encore Phone
CSU won't boot up
Problem is on its way to being solved. We called our vendor who contacted Intertel. Intertel is looking into problem. They have seen it before and are going to exchange the unit under warranty. Thanks for your response. Scott.
May 12, 2008 | Inter-Tel ECX 1000 Telephone
Interel voice mail rings
In System Timers change the System Forward Initiate timer. Be cautious that this is a system wide timer and will affect all users. If you want it done just on one phone it gets a little bit more complicated but it is still possible.
Oct 26, 2007 | Inter-Tel Axxess Corded Phone
Change Time and Names
On your Intertel Encore system you can program from a phone at extension 20. Intertel does not allow the sale of the manual to end-users (you) only Intertel dealers have access. I can help with the time change: From EXT 20 press the PROGRAM key, use the arrow keys to scroll until "System Programming" is displayed. It will ask for the password. The default is 1111, if it's been changed you may be in trouble... You would then select "System" then Select "Time and Date" - change the time (24 hour format) and date (MMDDYY) then hit the SPEAKER button to complete programming. I hope this helps. I have not done this myself, just passing on the instructions.
Jan 30, 2007 | Inter-Tel Encore 618.4001 Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
