How to connect dvd from equalizer to amplifier
  • 17,129 Answers
From your DVD you must use your Audio lines R & L ( maybe Red and White RCA cords) to the input of the equaliser's R & L . Next use another set of RCA cables to connect the output of the equaliser to the R & L of the Amplifier. Now your audio is connected, The video of the DVD can be connected tthrough your Amplifier's Video input- choose the input correspond to your DVD audio input.. can be 1,2 or 3. You can also connect the video directly to the TV if your amp does not have this provisiton.
Helpful? Good day
Posted on Jul 15, 2010
How do I connect a graphic equalizer to a Cambridge audio 851 amplifier?
I found only an 851A amp - I hope it is what you have or very similar. You can add an equalizer (or tape recorder for that matter) easily by making use of the amplifier's "Record In" & "Record Out" jacks. The amplifier's "Record Out" jacks should be patched to the equalizer's "In" jacks and the amplifier's "Record In" should be patched to the equalizer's "Out" jacks.
On the amp, select your source (1, 2, etc.) as usual. Press the "Rec In" button to divert the stereo source signals to the equalizer for customized shaping before being amplified - press again to bypass the equalizer and send the source stereo signals directly to the amplifier - and speakers.
https://techsupport.cambridgeaudio.com/hc/en-us/article_attachments/200291492/Azur_851A_User_Manual_English.pdf
Feb 25, 2015 | Cambridge Audio Azur 851A - Integrated...
Graphic equalizer
You connected your dvd player to WHAT mixer?
Connect your DVD to any one of your LINE IN jacks and your equalizer to one of the TAPE IN-TAPE OUT loops.
Apr 20, 2014 | Audio Players & Recorders
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
I want to attach an equalizer to my power amplifier. but How?
assuming the ouput of your car stereo is high frequency, then from your car stereo ouput connect it to the equalizer's hight frequency input and then the output of the equalizer's had to be connected to the amplifier 1 for your sub, What kind of equalizer are you installing, is it two way one way or three way?
Jun 08, 2010 | Audio Players & Recorders
How to install by myself
From your car stereo's audio out, connect this to your Equalizer's audio in, then from your Equalizer's out (sub connect it to your sub's amplifier audio in, mid out to your mid amplifier's audio in).
Sep 27, 2009 | AudioControl EQL 13-Band Car Equalizer
How do i connect multiple ampliers to one source and equalizer?
why do u want to use 3 amplifiers connected in series ?or even parellel.?remember in series amplifiers 1+1+1 does not make 3.it may make 10,hence the speakers may go bust .
Aug 24, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
Jun 15, 2008 | Audio Players & Recorders
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
248 people viewed this question
 Grubhead
Grubhead
