I have a model DGAT090BDE sealed combustion downflow gas furnace. It give a warning of insufficient fresh air intake. I have cleaned or replaced filters and it still gives the warning. How do I reset the warning and is there a repair manual available?
Light blinks three times and wont start
Posted on Sep 17, 2011
    President:
  • 1,902 Answers
The only way to reset the system is to unplug it for 15 minutes, then plug it back in. But if it is saying insufficient fresh air, then I would check your return air duct and make sure that there is not a kink in the link or a block in the line. If you are still having the issue after what I told you, then a relay has gone bad and the return air sensor will need to be replaced
Posted on Jun 01, 2010
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
Propane water heater high limit switch keeps kicking out
1) What brand and model water heater?
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake screen using compressed air or feather duster.
With AO Smith, craftmaster, state, reliance, american, kenmore, whirlpool, the air intake is located on bottom of heater. Rheem, richmond, ruud, GE, Bradford white, the air intake screen is located under combustion parts.
Water heaters today require plenty of fresh air. If air intake gets clogged with dust, then combustion byproduct moves up pipe too slowly for amount of fuel being burned, and this overheats combustion chamber.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Add a comment with more information
Dec 13, 2012 | Water Heaters
My smart water pilot is on but it is not heating the water tank
GE is Rheem.
Models change frequently.
Copy following link for troubleshoot resources by type of gas control valve.
Newer water heaters require frequent air intake cleaning.
To do this with Rheem requires removal of combustion parts, and then air compressor to blow out screen.
It is probably time to have a plumber give water heater a catch-up on recommended maintained, such as checking gas pressure, bleeding gas line, checking vent draft, clean combustion parts, clean air intake, check if gas control is working correctly.
Sep 03, 2012 | General Electric GE SmartWater Household...
How do you test a safety magnet on a robert shaw gas valve
Bradford White:
Bradford white service manuals:
http://www.bradfordwhite.com/documentation/residential/gas.asp
Depending on age of water heater, The air intake may need to be cleaned.
Remove combustion parts and use compressed air to clean arrestor screen located bottom of combustion chamber.
Get more fresh air to unit.
Check gas pressure.
Check color of flame, should be clear blue and not lazy yellow.
Install new gas control valve.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Aug 28, 2012 | Water Heaters
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot. I need ideas please
Clean combustion parts, clean air intake, get more air to water heater and see if problem continues.
Look at color of burner flame and pilot flame: if flame has yellow-and-orange instead of clear blue flame, then combustion parts need cleaning.
Pilot and burner problems can be caused by bad thermocouple, thermocouple not sitting in flame, weak pilot flame due to dirty tube or low gas pressure, air in gas line, no draft up vent, backdraft coming down vent, dirty combustion parts, clogged air intake, insufficient air, insufficient air quality, hot attic, bad gas control valve, etc.
Open following link for pdf resources, and illustrations for cleaning combustion parts, and some service manuals:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Water Heaters
Carrier furnace burner will not on with front panel close.
Sounds like a combustion air issue and by removing the front panel it lights and runs. Is there a PVC pipe connected to the cabinet that may have a blockage in it? There may be 2 pipes, one for exhaust and one for combustion air. Would not hurt to check both.
Jan 02, 2010 | Carrier Heating & Cooling
My goodman gaspack has had two incidents of cracked heat exchangerS within 18 months apart. Could something be cAUSING THIS TO HAPPEN?
Things to watch for when your heat exchanger is cracking....
1.Always kee the filter clean
2.Make sure the return air vents are clean and clear of obstructions
3.Your furnace could be Oversized for your house thereby running too hot.
4.The furnace can be "Overfired" basically burniing more gas and running hotter than it's supposed to be
5.It's always best to have your furnace taking fresh air for combustion from outside...basically you should have 2 pipes on your furnace ..one for Air Intake and the other for Exhaust
6.Sometimes some furnaces have a Bad Design and are prone to failure...Some Goodman have "Rings" basically large rivets that pop...this was a bad design however all the suggestions above should help but may not eliminate your problem
Oct 31, 2009 | Ruud UPMC036 Air Conditioner
York Gas Furnace Model # P2MPD14N08001A - Combustion Air
where are you getting combustion air from now in the midwest 1sq" per 1000 btu York.com with the model number
Jun 16, 2009 | Heating & Cooling
Coleman direct vent forced air furnace
I am a furnace technician and to solve the problem.You will find on the opposite side of the ignitor their is a flame rod with a wire connected to it.Remove it and clean it with sandpaper and re install it and it should fix the problem.If this is dirty it won't sense ignition and the board thinks that is it introducing raw gas into furnace and it isn't igniting and shuts off as a safety precaution.If you see a blueish tinge on the flame rod you should probably replace it.
Jan 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
