Question about Amana LWA40A
Need to know how to remove agitator on my amana/whirpool washer.
    President:
  • 1,902 Answers
The agitator will just pop off with enough working with it. There are no screws that hold it in place. Just some slight prying and some wiggling and it will come off. They are on there pretty solid so just work with it
Posted on Jun 01, 2010
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
How do you remove the agitator on washer model ntw4500vq1
USUALLY A 7/16 SCREW DEEP DOWN IN AGITATOR NEEDS TO BE REMOVED THEN SNAP OFF THE FISRT HALF OF AGITATOR AND U WILL SEE A THRUST WASHER THAT HOLDS THE CAM DOGS IN SIDE
Aug 26, 2014 | Amana Washing Machines
How do you remove the agitator on amana washer model lwa30aw
Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
Aug 06, 2009 | Amana 3.2 cu. ft. Top-Load Washer
How can one remove the agitator,it seems to move slower than it used to
If this a Whirpool manufactured washer (this includes Kenmore, Estate and Roper), the agitator can be removed by following these steps:
1, Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Some washers will have a fabric softener dispenser on the center post.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
If you have questions, or need additional assistance, please let me know.
NOTE: When reinstalling the agitator make sure you do not over-tigthen the bolt. This can damage the agitator and restrict its movement. Tighten until snug.
Jul 08, 2009 | Whirlpool WTW5500ST Top-Load Washer
I have a Whirpool LSQ9244EQO top loadong wsher. all sounds good and operates well other than the agitator. It is weak and sometimes appears to skip. The movement is not steady, but appears to be strong...
moz-screenshot-4.jpgHi, This is a two piece agitator. If the bottom half agitates fine, you will need to replace the dog kit located between the two halves.
Remove the rinse dispenser and the cap below it. There is a 7/16' bolt that needs to bw removed in order to remove the agitator. Once you get the agitator out, separate the two pieces and you can see the dogs.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
Washer
pull cap off top of agitator remove round cover underneath remove bolt in middle holding agitator down pull agitator up and out pull top portion off by holding bottom half down and pulling top part straight up in center of top part are what are known as agitator dogs either black or tan replace them they are probably worn whirpool part #80040
Aug 28, 2008 | Whirlpool Washing Machines
Washer will not start. Water will come in. Will not spin or agitate.
new washer? whirpool is manufacturer lift lid do you hear clicking sound left corner of lid if not ck screws in hinge that corner possible lid switch is not being struck properly when lid is shut also may need to adj hinge by pushing contact lever back a little ..older unit? possible same thing different location also ck wiring to motor
May 28, 2008 | Amana Washing Machines
Washing Machines Logo
148 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
