Question about Ingersoll Rand SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical
I have an IR SS5L5. We have developed a leak at discharge tube
I have an IR SS5L5. We have developed a leak at the fittings where the discharge tube assmbly goes into the head. Is there a seal at this joint that could be failing?
SOunds like your compression fittings have failed on the copper line. I recommend changing over to a stainless steel braided flexable line. Try www.mastertoolrepair.com they have the stainless hoses.
Posted on Oct 05, 2012
Compressor leaks after pressure is built up
The problem that you describe is more likely the check valve. Follow the air discharge tube from the pump to the tank. The brass or aluminum fitting at the tank is the checkvalve. Clean debris in valve or replace valve with generic. Should cost about 20 dollars. Make sure that the air discharge tube is clean of carbon deposits so that the new valve will fail. Good luck
Mar 18, 2013 | Air Tools & Compressors
When pressure switch is satisfied and turns off, air continuously blows out the side of the pressure switch
The check valve in the receiver tank is leaking. the check valve is located in the top of the tank where the copper discharge line from the compressor attaches. Shut off the power and bleed all the air from the receiver. Remove the copper line then remove the brass check valve. Once removed look in the check and make sure trash of some type is keeping it open. If trash is the problem clean and install. If not it will need to be replaced.
Dec 12, 2011 | Ingersoll Rand SS5L5 Ir Electric...
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Hi i have a 2004 ford f250 with a 6.0 diesel it has been running fine ...i shut it off for 10 minutes after 4 hours of driving and tried to restart and it cranks fine but does not start.......so ..... I...
Some trucks may develop an oil leak at the high pressure oil pump outlet fitting. This will cause a no-start condition as the computer needs to see at least 500 PSI before it will activate the injectors. In some cases the no-start will be intermittent and/or an intermittent stall with no codes will occur. If high pressure oil leak diagnosis indicates a leak at the pump, the pump outlet fitting (W301727) and the discharge tube block should be replaced with fitting and bracket kit 4C3Z-9B246-A. Do not torque the outlet fitting beyond 38 ft/lbs. If the leak is traced to the branch tube running through the engine block, replace with P/N 5C3Z9J332-B (requires removal of the transmission, flywheel and rear engine cover; new flywheel bolts required). I had this exact problem with my 05 6.0 diesel and it is an issue that the dealer knows all about.
Mar 29, 2011 | Ford F-250 Cars & Trucks
Standing in front of the SS5L5 pump pulley, looking at it,should it turn CW or CCW?
Easy to tell what direction pump turns. Look at pump pulley and notice and fan shape of the spokes. The pulley blows air across the pump. Most pumps turn ccw, however verify by looking at fan. Good luck
Nov 11, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Need to know type of oil it takes
I recommend type 30 all season full synthetic. It can be purchased on line, at an IR distributor and most Graingers.
Apr 14, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Water leaking by discharge tube
All you need to do is tighten the two screws on the discharge pipe (right on the side of disposal.) There is a gasket that needs tightening under the pipe fitting.
Sep 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Ingersoll Rand  SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical  Logo
159 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
