Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
  • 236 Answers
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressorSamsung window unit air conditioner - a73b784.jpg should shutdown when setting temp. will attain.
Posted on Apr 09, 2008
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
Freezing up inside my a/c unit
Often that is a sign it is low on refrigerant. It can also be due to low air flow due to either a dirty filter or dirt obstructing the fins (coils) behind the filter.
Jul 23, 2012 | Haier 5,000-BTU Mechanical Window Air...
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Haier ac unit keeps freezing in the front where the filter i located how do i prevent this
Freezing is a bad sign... but dont give up yet...
these are the signs that will cause freeze up...
dirty filter
t'sat not shuting off
cooling a room too big for the unit
settings at max but room is still hot
and the worst case... a/c leaking freon..
the leaking part is bad cause if you get someone to put it back in next year (or sooner) you have to call em back to recharge it again...
if everything checks out then it is the leaking freon... throw away...
what you pay $100 or so???
hope this was helpful
Apr 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Air condition unit freezes up
the unit may be too small for the room. or the filter need to be cleaned. also once a rea you need to sprey a mixute of warm water and amonia to clean the coils.
May 16, 2009 | Hampton Bay HBLG5004 Air Conditioner
LG Air Conditioner/Heat Unit spits cold air
I believe the "FP" probably stands for Freeze Protection and it's there to prevent your outside coil from freezing up and causing your head pressure to drop. To do this, it briefly has to reverse the cycle from heating to cooling. This is normal in a heat pump.
Feb 17, 2009 | LG Electronic Window Air Conditioner
Indoor unit comes on for 5 seconds and then shuts down
"Off" the circuit breaker and then "on" again then start the unit .
Oct 08, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
