Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer is making a clunk with every rotation, even when empty.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerMy dryer is making a clunk with every rotation, - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jun 08, 2010
4 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Posted on Dec 17, 2006
  • 686 Answers
SOURCE: dryer makes clunking noise
change your drum rollers
Posted on Mar 12, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer is making a clunking noise, even when empty
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 28, 2009
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
When the dryer is on it makes a loud clunking sound during each rotation
Check to see if something was left in a pocket when dried and fell out. like a coin, a magnet, a wrench. Often, things fall out of pockets and make a loud clunking sound when the drier is turned on.
Feb 05, 2011 | Dryers
My dryer is making a clunking sound on every rotation. It is still drying clothes but I'm sure somethings not right. thanks for any help
Remove the 3 screws on the top,back, of the machine and slide the top back and up to remove. Check all the screws that hold the baffles on to make sure they are tight.
Jan 06, 2011 | LG DLE2514 Electric Dryer
Dec 28, 2009 | Dryers
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Dec 11, 2006 | Asko T781 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
159 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
