Question about Freeplay Energy BayGen AM/FM/SW Radio
Rubber band broke on my freeview radio where can i get a replacement i have opened the radio to take broken band out but cannot find band to fit
Had rubber band fitted, instead of metal band, when new. Rubber watch band is perished and broken. I need a new metal band, Please. The model watch is :- Sector 700 2653700015
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Sector 700 2653700025 Watch
Need replacement part for 16-gal sprayer. It's the part that connects the hose to the gun -- hose end is broken off. What is this called and where can I get one?
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Jun 02, 2010 | Northstar Garden
How do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Oct 14, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
Broken the bottom print cartridge holder - blueish gray
The part has been broken in my printer for over a year now. I hold the cartridge in with a rubber band.
Apr 08, 2009 | Lexmark X2470 All-In-One InkJet Printer
Need Replacement rubber band for wireless headphones JW160R
I to broke mine and couldnt find a replacement part anywhere! called xbox and every game store and no one sells them. What i did was go on Ebay and bought a Broken AS IS Headset for $8 and took the earpiece from that and put it on my working earpiece. Thats the only way to get a replacement part trust me!
Mar 26, 2009 | Audio Players & Recorders
Broken Switch on West Bend High Performance food processor
We had this problem to but we were able to assemble with the help of a rubber band that held the switch on until the lid was locked in. Then you could use it the same way...pushing the rubber band down to engage the switch. I need to add though that since using this option...for nearly three months, The switch housing broke as well. I am now on the search for something to replace it I guess.
Nov 09, 2008 | West Bend 6526 Food Processor
Freeplay Energy BayGen AM/FM/SW Radio Logo
56 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
