Remote wont work unless it gets struck - Televison & Video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
Check your battery contacts in the remote . look for sighns of leaking batteries , the terminals may be dull and should be shinny. Clean with cotton bud and wd40 (switch cleaner) emery cloth .
Also change the batteries and make sure the contacts are tight against the batteries
Posted on Jun 01, 2010
Playing ipod on samsung MME460D
I've just been struck down with this too on my newly purchased MM-E460D. I think I've worked it out, its just a poor description and manual. iPod mode" means choose the music off the iPod via a connected TV whereas "Remote iPod" is choose the music off the iPod via the Samsung remote and also directly from the iPod interface. I've been there for days trying to get "iPod mode" to work via the iPod interface.
Oct 01, 2012 | Samsung HT-Z310T Theater System
The tv continuously changes channels and the tv's on top buttons won't work accept for the volume up
Check for any struck press buttons at the control panel of the TV. This is a common fault that, these switches to get struck, preventing any more functions to do with them. There is no repair to these micro-switches, except replacing them. You have to open your TV to access this control panel printed circuit board, de solder out these damaged switches, and to solder new ones in place. It will be best to replace them all at one time. These switches can be bought from most of the electronic spare part selling shops at your town. if you are not handy with electronics, seek help of any experienced service technician.
Aug 04, 2012 | RCA F32450 32" TV
Lens cover wont open full on start-up. You have to finish it manually
The fault of a lens error be it in the shutter, zoom or auto focus is due to failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Aug 08, 2011 | Cameras
MY CAMERA WAS NEW AND IT WONT TURN ON. IT IS A pENTA OPTIO a10
If the camera is a new one then do not attempt to open but take the warranty cover.
If is possible that the lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Jul 14, 2011 | Pentax Optio A10 Digital Camera
I accidentally dropped my samsung ES71 camera from a short distance and now it wont focus at all. Is there a way to fix this?
The lens focus error is due to failure of the lens control system.In this case it can be a mechanical DISLOCATION and so might need to open to reset the mechanism. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Jul 13, 2011 | Samsung Cameras
My lens is extended and won't retract. I have taken out the battery and it still wont go back to the off position
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Jul 07, 2011 | Polaroid t1031 Digital Camera
Everything comes on but wont start wont even turn over ever since my house was struck by lighting
seen the film, war of the worlds, when all the cars went dead, well so has yours, in the same way,its called Electro Magnetic Pulse.and it kills all your relays.and computer engine management systems.this is not an easy job as you will have to connect to a diagnostic machine while you are searching for faults,unless you are a dab hand at car electrics,get it done by qualified vehicle technician.
each system has a potential fault,and you have loads.
Jun 18, 2010 | Cars & Trucks
Nothing works.
Remote receiver got fried by the voltage spike. If you have pull chain controls as well, you can remove the receiver and possibly be able to save the fan, but the capacitors, may have also been fried. If the capacitors are fried, then most likely the motor experienced some seriously high voltage too, which would mean I would replace the fan. I assume you have had the house's wiring inspected? If lightning struck the house and killed the fan, then it likely ALSO damaged other electrical components. If the lightning struck your power transformer and not your home directly, you may can get the power company to pay for this ceiling fan as the transformer is supposed to have a lightning arrester on it.
Mar 31, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
My 500 gb unit was struck by lightining and the power source light wont come on. I have taken the drive out of the case and put it into a duo pro drive but it is still not working
most likely case the electronics board attached onto disk is fried. replace it and there is like ~60% chances that this was only problem and drive will go back online
Oct 10, 2009 | Western Digital My Book World Edition 1TB...
Tv struck at aux channel
Hi, can`t be done without the remote, list model number and I`ll see if the remote is still for sale & give you the part number for it, BMW Rider
Jan 14, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
