Question about GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
Which way is the switch on for th eice maker circle or staight line
  • 4,070 Answers
Circle is on
Posted on Jun 01, 2010
How do i set the timing on an 87' kawasaki 454ltd?
there are two flat head screw on left side side cover take them out one will have a nut to turn crank will looking in other hole turn motor till u seee a T with a line now the should be a notch in the threads of the hole u are looking through line the line beside the T with the notttch u see now with valve cover off u will see ether one circle or two straight lines one the gear attached to crack if it is one circle put that straight up or if two lines adjust them till both lines go staight (side to side) with the top of the head
Feb 11, 2014 | Motorcycles
Ice maker stopped filling with water
where the tube (water supply)cumes into the ice maker inside the freezer may be froze shut /locate it and see if it is use something small to open it up easy!
Apr 10, 2013 | Kenmore Refrigerators
I HAVE A 2011 NISSAN SENTRA WITH THE B1210 CODE(EIC SWITCH-2 ASSEMBLY CIRCUIT OPEN)
DTC - B1210 COLLISION DETECTION
The air bag diagnosis sensor unit will set this DTC if it has detected a collision which has resulted in a frontal or side deployment of one or more air bags or pre-tensioners. If this DTC is detected after a SRS repair, the air bag diagnosis sensor unit has not yet been replaced. This DTC can not be erased. Please see the dealer on this.
Oct 23, 2012 | Cars & Trucks
What does check dcl mean
DCL is Data Communincations Link... the communication connection between the computers in the instrument cluster and the rest of the car. its usually caused (99% of the time) by a bad connection.
The Data Communications Link (DCL) is a wiring system that allows the sharing of information between the Electronic Engine Control System (EEC-IV) , the Electronic Instrument Cluster (EIC) and external equipment.
The EEC-IV system transmits the following information through the DCL to the EIC:
Engine RPM.
Engine coolant temperature.
EEC-IV malfunction indication.
Fuel used.
The DCL system transmits Malfunction Indicator Lamp (MIL) information to the EIC. The EIC uses MIL information to generate a CHECK ENGINE warning in the event of an engine sensor failure.
The EIC will display the message "CHECK DCL" on its Message Center Display if it is not receiving data from the EEC-IV. This warning is turned off whenever data communication is restored.
The EEC-IV monitors the Data Communication Link for faults. If a fault occurs in data communication a continuous Memory Code is set in the EEC-IV. The DCL Codes (529 for EEC-IV and 533 for EIC) can occur separately or together. These codes are not immediately cleared when data communication is restored.
The existance of a DCL code does NOT mean that a module has failed. also I would check for an oil leak or coolant leak that would be the cause of the smoking under the car.
Check this link for some help on fixing it: http://www.lincolnsonline.com/tech/00086.html
Hope helps.
Sep 11, 2011 | 1993 Lincoln Continental
When i switch on my Vivitar Vivicam 7024, it switches on normaly and resumes normal function (e.g. taking photos, videos, and looking at images). but the screen itself is damaged, it has a large black...
I'm sorry to say that but the screen of your camera appears to be damaged.
May be YOU didn't drop it, but someone else might have. Most probably the screen was pressed hard against something (might be while stored). That's what the black circle and colour lines suggest. The colour lines are somewhat like colours you see when oil is put on water, isn't it? That means the LCD screen is damaged.
I suggest to take it to repair shop and get the screen replaced, specially if you don't have experience repairing cameras.
Aug 30, 2011 | Vivitar ViviCam 7024 Digital Camera
Screen says brewunit blocked. Brewunit seems clear but stops in wrong position, ie not 'home' any ideas? Thanks
Hi If you remove the brew unit and put everything back with out it the brew unit. Turn th machine on and see if it will cycle? Open the door and look in the back where the brew unit was. There is a cog in the back with teeth. There are 2 large teeth, and they should be at the 10 and 12:00 position roughly. If they are anywhere else you have a broken drive and need to get the gears replaced. If they are in the correct position check the front of the brew unit where the circles are. There are 2 diamonds and they should be pointing at each other. if they are not you need to bring them together with the key tool. Insert it into the center of the circles and turn until they line up, then put back into the machine, and see if it will work. If it still doesn't you have a bad board.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
It not going in to 4x4 when button is push light not coming on
Typically, there are gears that need to align after 4 wheel engauge request. These gears relate to the front and rear wheels.... These two systems need to be moved in relation to one another. THIS means drive the car, (not in a staight line, as nothing changes) in a circle or turn to the right and/or left.
The same issue is present on disengauge. Commonly there is some preload and the system will not disengauge. Employ the same strategy.
Sep 05, 2009 | 2001 Mazda Tribute
Panasonice TH-50PE8U Red/Purple Line
take a rotary vacumm and make circles on screnn make sure tv on and vacumm, back up slowly making circles that take up the whole tv, repeat this s couple times, it goes away
Jun 22, 2009 | Panasonic Viera TH-50PX80U Plasma TV
I have a 13 year old refrigerator with an icemaker. I installed a water line to get water to the fridge. The hose is connected to the water main and the fridge. I am not getting any ice.
Obviously, your ice maker problem could be any number of things... Now that you have water to the ice maker, is the inlet valve opening to allow water to get to the ice maker itself? If it is, is the line that runs between the inlet valve free to allow water to get to the ice maker? if it is, is the ice maker cycling ( meaning the motor rotates the drive mechanism that times the cycle of opening the valve, rotating the mold tray then releasing the ice with a small mold release heater? An ice maker that's ~ 13 years old probably has a removable front cover so that you can see the drive gears.. Also, is the lever that senses the ice cube bin is over full in a position ( normally down) that allows th eice cube maker to cycle? Hopefully, these simple checks will help you trouble shoot the problem and get your icemaker functioning again. Hope this helps !
Aug 14, 2008 | Amana Refrigerators
GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
