Question about Hotpoint Refrigerators
Model ctx216gasmrwn trips breaker when it gets to defrost, freezes fine
    President:
  • 1,430 Answers
I would first check your defrost heater for continuity, if the heater is good the defrost timer would be the problem. Heres a couple links one for the defrost heater and one for the timer.
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/refertopdefrosttimer.html
Posted on Jun 01, 2010
The breakers at the electrical panel keeps tripping, would work fine for awhile then it trips
Sounds like a shorted defrost heater, it shorts after a period of running when the machine initiates a defrost cycle... Defrost Heater Assembly 242044113
Mar 18, 2016 | Freezers
Trips power when the defrost mode turns on
There is a heating coil in the freezer that comes on to assist in defrosting. It is most likely shorted. When it comes on to defrost it trips the breaker.
Aug 19, 2015 | Jenn-Air Refrigerators
I have a GE freezer, model number FUF20DPARWH that blows a ground fault circuit breaker when it goes into the defrost cycle. The case is not "hot" when this occurs and it is plugged into a circuit th
Ralph, the only way to be sure of what is going on is to check the amp draw of the freezer when it is in defrost. If the amp draw is in range ( listed on model/serial tag ) you may have a GFI that is weak.. if unit does not defrost there will be an ice buildup on the lower half of the back wall... But with unit tripping GFI it probably is defrosting............ Ken Hawk
Jan 28, 2015 | GE Refrigerators
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
Freezer trips breaker
If it is tripping the breaker when the unit is in defrost this is will not be the capacitor. You could have a heater or defrost thermostat issue. Please contact a professional for a full diagnosis.
Jul 30, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerators Logo
48 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
