Question about Amana DRS2660B Side by Side Refrigerator
The rubber molding will not keep shut... yesterday I leaned into the ref. area my left arm hit the molding between the freezer and refreg... it was very hot. why?
  • 4,070 Answers
The door closing problem is usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Door not shutting.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Jun 01, 2010
What fuses go to air ride on 2003 Lincoln navigator. The passenger side is sitting low
look at the control arms for a link that goes from thee sensor to the control arm the rods fall off and then the truck leans the whole system is controlled by one fuse with the shut off switch in the left rear cargo area
Sep 10, 2012 | Cars & Trucks
Hi, We emptied our ice bin yesterday to fill an ice chest and the ice maker hasn't worked since. The automatic shut off arm is stuck in the down position and the entire ice maker compartment is...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 11, 2011 | LG LFX25960ST Stainless Steel French Door...
My frezzer does not work for lg refregator
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 24, 2011 | Refrigerators
We have a ge pds20mcr bottom freezer ref and have a foul odor coming from the bottom of ref.
If the odor is only present from the bottom of the fridge, and not inside the freezer or when it is shut, it is most likely spoiled something. Put everything in a few coolers, cover with ice and close up, spray out the fridge with some cleaner and let the freezer defrost if there is ice buildup on racks or surfaces. After the fridge is clean, I suggest using a box of baking soda to keep odors out of your fridge. Arm & Hammer recommends replacing these boxes every 30 days, but I've had mine in there for 6 months or so and it helps.
Dec 03, 2009 | GE Energy Star PDS20MCR Bottom Freezer...
GE SideBySide Ref GSS25VGMD WW
if temps are ok, i honestly don't think you have a problem
Jun 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
My Fridge was turned off for the winter while I was away. Unfortunately my plumber left filled ice cube trays in the freezer and shut the door. Water was also left in the fridge. When I returned this...
well for mold problems i recommend cleaning out all compartments with water/bleach solution also a little bathroom cleaner will kill the mildew. i don't think it seeped to the insulation because the plastic liner in fridges are quite little thick. turn it on for some days and put one of those arm and hammer baking soda for fridges that will kill any residual odor. i consider it safe but its your call if you feel comfortable using it.
Apr 21, 2008 | Refrigerators
Amana DRS2660B Side by Side Refrigerator Logo
129 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
