Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hi,my hotpoint df 41 trips the mains every time it starts the heat water cycle.I assume the element is faulty.I have looked underneath and all seems dry and clean.Can i buy and fit a new element myself?
  • 192 Answers
Yes, you need to remove the element taking note of the connections and wire colors. Also note the seals used on the element. Remember that sometimes a "cold" element does not show the fault and only once heated does the "short circuit" show. Take the element with you to the dealer as many different elements (shapes and sizes as well as electrical connections on elements are available).
Posted on Jun 01, 2010
Testimonial: "Very helpful input,thank you."
Hi There, please can you help. My Hotpoint BWM129 is not heating up the water. I have checked the Element which is OK (30ohms). Have you any solutions to this issue. Greg
Make sure you have 220 at the elements. If the circuit breaker in the power panel for the house has one tripped but not the other then 115 volts will be available for the motor, timer and lights, but the heat element will not heat.
Jan 03, 2015 | Hotpoint Washing Machines
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Hi, i have owned my Hotpoint Ultima WT960 washer for 3 years now with no problems, however recently the washer keeps tripping my consumer box. it only trips on the main wash cycles and is fine on rinse and...
I would concur that is probably the element and or thermistor attached to the element that is causing the problem.
Before commiting to replace, try disconnecting the supply to the element and trying it again, if it does not trip, then this proves element and or thermistor faulty.
Jan 04, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint DY46X: When turning on the main oven it immediately trips out the power circuit.
If it is a fan assisted oven, then I would suspect that the oven element is faulty, disconnect the element, and try again, if it does not trip, then element is faulty, if it still trips, then you are goimg to have to look elsewhere for prob.
Please rate my solution.
Thanks.
Oct 19, 2009 | Hotpoint Ovens
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
208 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
