Question about HP LaserJet 4250n Printer
Network printer shows offline on computers but no error message on printer itself
    Genius:
  • 1,112 Answers
Hi;
Usually when a printer show offline it is either because windows does not recongnize the driver, or the printer is not set to be the default printer, I suggest you try reinstalling the driver first, and check printer settings to make sure the check is there for default printer. IF all else fails try going to control panel and printers icon and click, then click add printer choose the option add a network wireless or bluetooth printer. It should list your printer if not then click The printer i want was'nt listed, then click add printer by TCP/IP address or hostname, At this point you will need the IP address for the printer on the network you are trying to use. Enter the address then click enter, the system should find the printer on the network.
Posted on Jun 01, 2010
2 Suggested Answers
  • 35 Answers
SOURCE: printer is offline message appears (printer is networked)
change your usb cable.or try to reinstall the driver again
Posted on Feb 16, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Keeps showing offline even though I put in new cartridges and it cleans. When I test print, I have to do it manually and the paper comes out blank. When I check the ink status for some reason it shows...
First unplug your printer from the computer then uninstall you installed driver . After that plug it to the computer and install driver again. Then restrat your computer after successfully instalation. If still now ggive the problem then install driver from the below link and install it.
http://download.cnet.com/Brother-MFC-240C-USB/3000-2110_4-99329.html
hopefully it will be work. Other wise go to the servicing center.
May 04, 2011 | Computers & Internet
Error message says network printer off-line
For turning on the offline mode, firstly you have to firstly click Start. You have to take the Control panel.
In that, you would select the option named 'Printers and Faxes' icon. When you click that it would open a window.
That window would show the list of printers which are being connected to the system.
Then, double-click the printer in which you have to change the mode. A pop-up window would then appear.
You would go to the printer in the menu bar of that pop-up window. Lastly uncheck the 'use Printer Offline'.
After performing that the printer would go into the online mode.
get more help to fix Network Printer Offline Error hope this helps you.
Feb 25, 2011 | HP Deskjet 6940 InkJet Printer
I cannot print with my deskjet F2200, its showing error-offline, please advise how can i rectify this printer problem..
error-offline means that the printer is not connected to the computer, so what info i need is this printer connected with a cord or wireless? also are you using the network to connect to the printer?
Jan 23, 2011 | GPS
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
Dec 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Dell 3100cn Printer
Hi Lillie,
No, the message for RAM disk has nothing to do with your issue. RAM disk is an option for that printer, but most users do not have that option, and if you accessed the menu for the 3100 on most of the machines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not mean that your computer is communicating with the printer. In Fact, that message would show up even if you did not have it attached to any computer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the "reports" menu. Select either the printer settings, or the PCL Fonts report. When selected, the printer should print which ever report you selected.
One thing you may want to check is to see if there are any print jobs " locked up " in the print spooler on your computer, and also make sure that the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job that had a problem and is "stuck". This will prevent any job sent after that to be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clicking on "printer" from the menu and ensure that work offline is not checked.
Good luck.
Oct 06, 2008 | Dell 3100cn Laser Printer
OFFLINE problem - unable to print
if your printers saying Offline, it means that your printer is not connected/switched on or detected by the computer.
Try a hard reset or re-installation of the printer itself.
power on/off ( On the printer )while this error message appears.
Check the cable from Printer To Computer.
Mike @ Compurepair.
Feb 23, 2008 | Computers & Internet
HP LaserJet 4250n Printer Logo
506 people viewed this question
Seeker5211
Seeker5211
