Question about Copystar CS-1810 Copier
Copystar gs1810 replaced th toner but I can't get
Copystar CS1810 replaced the toner but I can't get the ad toner red light to go off is there a certain procedure for this.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Copystar Expert
  • 170 Answers
Make sure you have copystar toner not kyocera or try to shake the cartridge real good
Posted on Aug 03, 2010
    President:
  • 3,085 Answers
The toner auger is probably clogged up. You will have to disassemble the whole dev unit to clean it out.
Posted on Jun 01, 2010
How do I fix this copystar CS1810 error code E71
check the top original feeder switch they get pulled wrong way and stick insert a thick piece of cardstock in original feeder slot and push it in until the switch is able to move freely
May 24, 2014 | Copystar CS-1510 Copier
Copystar CS1810 shows error code J00. How do I fix this?
J00 means that the machine did not pick. remove the cassette and the put back and press start again
Feb 15, 2011 | Copystar CS-1810 Copier
Replaced toner and waste toner container, but there is still a 'add toner' red light
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key.
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.
6. Enter the maintenance item number (130) using the up/down keys.
7. Press the enter key. A selection item appears.
8. Select On using the up/down cursor keys.
9. Press the enter key.
10. Turning the power switch off and back on. ADDING TONER is displayed and installation of toner starts.
11. After approximately 15 minutes, the installation is completed and the machine becomes ready.
Jan 08, 2011 | Kyocera Copystar CS-1820 Black and White...
Copystar 1810 GS
that's because it thinks it's out of toner. keep opening and closing the front door and let it run.
Jan 21, 2010 | Kyocera Copystar CS-1820 Black and White...
Code "ap"
means copier is adding toner. you maybe able to install new toner and message will go away. also may be bad developer or sensor. replace the toner firsrt. if it does not fix it call a tech
Dec 30, 2009 | Copystar CS-1530 Copier
I just replaced the toner. Toner light on
Keep opening and closing the front door until the toner catches up. Did it have a plastic seal that you forgot to pull off?
Nov 25, 2009 | Copystar CS-1810 Copier
Our copystar 2030 keeps asking for toner. We just
Can be an ensemble of the reasons:
1. The Silent sensor which checks the concentration of the toner.
2 Check pulled of you film defensive with tubas?
3 During moving the toner track can be broken or littered.
4 Can be a value-added degree to concentrations of the toner in service programme inflexion
5 Can be sensor itself to concentrations
7 Sensors can be littered
8 If it is used developer, can be violated concentration developer to toner
This in a complicated way repairs with words.Sooner whole you should apply to service,forgive, but such fault it is difficult do advice, it is necessary all look the experienced specialist, you may lose much toners and break the track of the presenting the toner, apply to service. Good luck
Oct 07, 2009 | Copystar CS-2030 Copier
Shows an AP error. what does this mean?
Your copier is adding toner.Since they cant make a "T" with a 7 segment display, they used a "P" for powder.If it does not go away, replace the toner cartridge and wait a few minutes. Good Luck!
Apr 21, 2009 | Copystar CS-1510 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Copystar CS-1810 Copier Logo
207 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
