Question about ASUS P5GZ-MX Motherboard
How to troubleshoot the error message of my pc? CMOS Checksum Bad Chassis Intruded! Fatal Error...System Halted.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Looks like you have a bad ground connection in your motherboard, check all the connections , then restart the machine with the minimum devices conected...
thanks
Posted on Jun 01, 2010
Cmos checksum bad Chassis Intruded Fatal Error System Halted!
To remove CMOS Checksum error, you have to remove the coin cell battery from the motherboard and install a fresh one. A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For Chasis Intrusion msg, go to the BIOS (when prompted, press the Function Key at the system startup) and locate the option of chasis intrusion option and disable it, save settings. Commonly, to enter the BIOS you have to press F2, F10 or DEL Key, depending up the make/ model of the PC you have.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 08, 2011 | Computers & Internet
Cmos checksum bad.chassis intruded fatal error ..system halted.
Make sure that the Processor Heatsink is tight. Try replacing the CMOS battery.
Hope this helps!
Apr 15, 2011 | ASUS P5P800S Motherboard
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ASUS P5GZ-MX Motherboard Logo
362 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
