Question about LG 37LC7D 37 in. LCD HDTV
REMOTE IS NOT WORKING
My remote is not working. The remote works fine on other tv so I think it is the sensor on the tv itself can you assist me
    Genius:
  • 1,112 Answers
Hi:
This usually indicates that the remote receiver or IR as its call is faulty in the television, this is a releatively cheap part to replace but you will need to know how to unsolder electronic componets and resolder them. But before replacing the sensor check the supply voltage to it, it should be 5 volts on one or two of the pins if the voltage is there then replace the sensor..
Posted on Jun 01, 2010
Toshiba 43" 43H70 Projection TV - Remote Sensor not working
Here is your manual
Someone else with same problem
Seems like they you may have sensor problem, remove board and check solder connections and/or replace IR sensor bad pic below of toshiba sensor board below.
7151e29.jpg It should be hidden behind the smokey plastic cover in the right corner of set,
Dec 30, 2007 | Toshiba 43H70 43" Rear Projection...
Remote control senser failure in tV
It can be replaced. Contact any service tech:.
Mar 23, 2013 | Toshiba 36A41 36" TV
I have had several technicians at my parents house they have a sanyo pdp42xr9da with remote rcj17oa the remote dosent talk to tv we have had the tv for two years it did work but now dosent please suggest...
Most of the fault in this kind of symptoms is the remote control itself.
To confirm it, aim directly the remote control to your cellphone camera and press any button key at the remote control. While pressing the button key, you will be able to see the flash of the infrared indicating that the remote control is working fine. If you can't see the flash of the infrared this is an indication that the remote control is already faulty.
Remote control
If you've confirmed that the remote control is working fine, then the fault came from the infrared receiver(sensor) of your tv. It needs to check by the qualified technician to isolate the problem.
Feel free to ask question of you need further assistance.
mjsazon
Oct 04, 2011 | Televison & Video
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
My tv won't turn on with the remote. The remote works fine
You can try www.encompassparts.com The remote sensor is located on the main board up close to the buttons. It is a 3 legged part that is exposed to a small window in the front cabinet. Thanks for using fixya.
Feb 23, 2010 | Panasonic Televison & Video
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Remote control issues
Yes it is a quessing game. If we experts do not have the set in front of us to trouble shoot, but I will explain the process. First off to work on any tv set, your going to need a schematic diagram or should have one, or it will be a crapshoot. Next set up your osilliscope and multimeter. First check the B+ going to the IR sensor. If its at 9 to 15 volts, and is clean without distortion, Im thinking that is ok, but check the manual to see what it is suppose to be. Once the B+ is confermed good. Place the scope probe to the data output on the IR sensor while pressing a remote funtion. If the date is clean looking and is present then the IR sensor is good. If it is not good or noisy, replace the IR sensor. In the event its there, trace the data signal with the assistance of the schematic diagram, to the microprocessor, through all the jumpers and plugs and componets, like coupling capacitors or resistors, as I have found bad solder connections on the route to the microprocessor. If the same data signal is on the input of the microprocessor remote input, that is on the data output on the IR sensor, then replace the micro. This way of troubleshooting, has in the past, fixed every remote problem I have encountered with a remote intermittant, or no remote operation. Good Luck
Oct 07, 2006 | Toshiba MD13N3 13 in. TV/DVD Combo
LG 37LC7D 37 in. LCD HDTV Logo
138 people viewed this question
Computer Repairing
Computer Repairing
