Question about Ruud UBHC Air Conditioner
Replace drip pan
I have an old Rudd H&A/C 3.5 ton unit, the A/C drip pan is rusted out and leaking.
A local repair outfit recommends replacing the condenser coil & the drip pan, a $900 job, can just the drip pan be replaced instead?
If so what's a reasonable price for the job
5 Suggested Answers
Stickx
  • 148 Answers
SOURCE: Condensation pan replacement
im one of your techs i did some research thanks
Posted on Jun 28, 2008
skrbin
  • 121 Answers
SOURCE: condensation from the coils
check drain hose maybe is obstruct or have bad plunk.
Posted on Feb 17, 2009
farfield
  • 462 Answers
SOURCE: Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to rep
A new unit will be 13+ seer unless you can find someone that has replaced a compressor or has one left over from pre 2006 stock. Our wise Government with all its resources decided that we aren't smart enough to turn off the lights to save energy, so they chose to end the med and low price lines. And the same bunch of smart ones decided that now R22 because of its chlorien content being bad for the air (5% of what R12 was) so we have R410A and others that no one knows how much cancer or daMAGE THEY WILL DO OVER TIME. So now if you replace your AC unit out side with a new one be sure its compatable with the refrigerant inside and beware soem manufacturers wont stand up to full warranty if you dont buy an indoor coil and rerplace it too.
We get what we deserve in Washington DC and if our guy didnt support this stuf too many other folks guys did. We just dont talk about it enough. AND WE SHOULD. But then again you like me are probably RITCH. So we have to give up our wealth to the government so they can redistribute it and buy more votes. And we can stay working too much to talk about it.
Just burns my back side like a 4 foot flame.
Read tween the politics and you'll get my recomendation.
Buy your self a compressor and get someone qualified to install it or see if the old goodman one will interchange easily.
Posted on May 12, 2009
kingbrizzle
  • 407 Answers
SOURCE: I have a 3 ton split system using a Rudd 3 ton
Only if they are still available in your area. Goodman still has a few R-22 units left in Texas the last I heard and that is only if your local supply stores can order them. They are getting to be far and few between since they have stopped making the equipment. You might also get a second opinion, a lot of companies are just trying to benefit more by replacing everything, but you could still have a R-22/410A compatible indoor coil and copper line set, they just have to use a flush kit to get all the old refrigerant out of the system. 410A is easily contaminated and runs at a lot higher pressures, that is why they want you to replace everything, but there is still hope. It will save you a little money just having the system flushed and replaced with 410A condenser, but only if compatible. Hope this helps and good luck!
Posted on Aug 19, 2010
Testimonial: "Thanks for your help."
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Replacement for 20yr old A/C system
I you have a 2.5 ton condenser on a 3 ton coil, and he gave you an estimate for a 1.5 ton condenser only, he missed something, or you need a second estimate. Now if give you an estimate for a complete system, with a 1.5 ton condenser/evap, coil, your ductwork will/may be oversized for that unit. Need a second estimate. You've been happy with a 2.5 ton cooling capacity in the past, don't settle for anything less, unless you've completely updated with new doors, windows, insulation, ect.... I'd call around and ask for an estimate, with a load, and then ask for the cooling tonnage and furnace BTU's from that load, when they call with the price. Most reputable companies will/can prove a proper load calculation and my city just made it mandatory to prove a load was achieved when a permit is pulled due to the Dept. Of Energy passing laws on this subject in 2015. Ask if its mandatory for a load calc. if they pull a permit. And they are supposed to pull a permit in city limits I'm sure. It's not a good practice to miss match systems with current designs. 20+ years ago it was, but now there are codes against this practice. And also shortcuts to try to make more money with less invested may not be considered GOOD PRACTICE. Hope this helps!
Mar 13, 2017 | Heating & Cooling
A lot of water leaking
You probably have a clogged drain line. Unplug the fridge for 24-48 hours with a towel by the drip pan for a simple fix.
Jan 22, 2012 | Kenmore Side by Side Refrigerator
My ford windstar 2003 is leaking from de oil pan by rusted
I think you know what has to be done, if you got under the
van & actually checked it out
You remove the oil pan,repair or replace it
& reseal it
Sep 23, 2011 | 2003 Ford Windstar
I have a GG40T06/487-246 GE SmartWater Water Heater, it is about 10 years old and now there is leak on the position of the stem of the reset button connecting to the gas valve. Any suggestions to replace...
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Jul 19, 2010 | General Electric GE SmartWater Household...
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
Ruud UBHC Air Conditioner Logo
297 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
