Question about RTO 50cc Moped Scooter
I have to rev my piaggio typhoon quite alot before it moves can you think of any think it might be ? i would be very gratefull
  • 45 Answers
Sounds like its the springs inside your clutch
easy fix and quite cheap to
Posted on Sep 02, 2010
1999 Piaggio Skipper 125 lx fork oil capacity Best regards Pawel
Hi, Pawel for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Piaggio, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Piaggio and Vespa Haynes Online Manual for Piaggio Sfera Typhoon Zip Fly...
https://www.oemmotorparts.com/oem3.asp?M=piaggio&T=skipper%20lx%20125-150
Piaggio Skipper ST 125 2005
Piaggio Wikipedia
Apr 12, 2017 | Piaggio Motorcycles
How to rebuild a piaggio 125 typhoon engine
Great question! But do you really think someone can go thru the entire process of an engine rebuild online, in text, with someone we cannot bi-directionally communicate with in real time, unable to see what you are seeing and be able to pull that off effectively? It's admirable you want to take on the project, but you need someone with knowledge that has a physical presence where you are to assist you in this endeavor.
Sep 08, 2016 | Piaggio Motorcycles
Where does the hose go as it has come off and my piaggio 125 typhoon won't start
Hi, Anonymous that looks like a vent tube for the battery one end goes to a nipple on the battery the other end points to the ground should go past the bottom of the frame but would not stop the bike from starting but the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Faulty fuel pump fuse or relay.
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
https://answers.yahoo.com/question/index?qid=20111209091028AAKgrJ1
https://www.reddit.com/r/scooters/comments/3d1r2j/help_please_piaggio_typhoon_wont_start
Modern Vespa Piaggio Typhoon 2012 125cc HELP please
https://www.tradebit.com/filedetail.php/198628390-piaggio-typhoon-125-4t-2010-2012
Mar 26, 2016 | Piaggio Motorcycles
Code 001136 Exhaust emissions - Adjustment screw fell out. Can I just cap it?
Hi, Jonathan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2005+piaggio+typhoon+50
Aug 25, 2015 | 2005 Piaggio Typhoon 50
Code 001136 Exhaust emissions - Adjustment screw fell out. I can cap it off or do I need a mixture?
Hi Jonathan, I am sorry you can't find the first and best tool you ever bought for your Piaggio but despair not for a mere $15 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Aug 24, 2015 | 2005 Piaggio Typhoon 50
Back light dim when start up then get brighter
Normal.
When the ignition is first turned on (but before the engine is started), the light is running just off the battery, which may not be fully charged.
When you engage the starter, this is the biggest power draw there is from the battery, causing the light to dim even more.
Once engine is running (if everything is working right), the alternator powers the light, as well as everything else.
In fact, if may/may not get brighter as you rev the engine.
Feb 17, 2014 | 2010 Piaggio Typhoon 50
I have a piaggio typhoon 50 cc (1999) it starts on the kickstart and ticks over but dies when you try and rev it,It wont fire on the electric start but turns over fine.The carb is clean and the fuel...
Hi, Steviethemas before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.49ccscoot.com/manuals/Piaggio_Tech_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=piaggio
PIAGGIO ZIP 50 2T User Manual
May 16, 2017 | 2005 Piaggio Typhoon 50
My Piaggio Typhoon 50cc has no indicators or horn
Look under the front panel and make shure all the wires are plug in. check www.scootdawg.com for a complete list to trouble shot it.
Best Reguards
Larry
Jan 24, 2010 | Peg Perego Vespa Scooter
RTO 50cc Moped Scooter Logo
259 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
