Question about Dometic RM2852 Refrigerator
Not cooling in hot temps
My Dometic Rm2852 warms up when outside temp go above 85 degrees. We have tested alot of the voltages and installed a extra exhaust fan to move air but still fails, it's been like this since day one in 2005
  • Mike Butler
    Mike Butler Jun 05, 2010
    Have you contacted dometic directly, and if so, what did they say?
  • Dometic Master
  • 6,674 Answers
Double check clearances around fridge, which should be zero on sides and top, as well as check baffle in stack, which should be 1-7/8" above burner. Also check door gaskets with paper (it should drag through when doors closed. Does the burner stay lit when on propane, even though temperature is increasing inside fridge?
Posted on Jun 05, 2010
Replaced a starter capicator, now it just bloweswarm air
On hot day your unit may not cool enough. Make sure that outside unit is clean, filter inside should be clean. If all above is good your unit may be low on Freon.
Aug 11, 2014 | Dometic Heating & Cooling
2000 nissan altima blows cold until outside temp reaches 90 degrees then blows hot
2000 Nissan Altima Heater Air Condition Section HA 76 pages Here is factory service repair manual for your vehicle . Do you know how to do testing on these system ? Automotive electrical system testing ? How to read a wiring diagram ? When hot outside is the inlet pipe to evaporator freezing up ? Do you know where this is , under the hood in the engine compartment at the fire wall . What are gauge readings , Is the compressor engaging ? Were any switches replaced ? Ambient temp. , thermal transmitter switch . pressure etc...
Apr 25, 2017 | 2000 Nissan Altima
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Warm temps cause cupboard shelf above refrigerator to heat up
well thats normal mate you cannot prevent this ... perhaps try draging your fridge away from the wall so it sits about 100mm off the wall
Nov 11, 2009 | Dometic RM2652 Refrigerator
Does not heat real hot or cool real cold . dometic duotherm penguin markings on 85 or so unit
Heat real hot? Is this a heat pump or do you have a heat strip installed. Get a regular thermometer and put it in the outgoing vents of the unit. Register the temperature there and then the outside temp. If it is cooling at 17 to 23 degrees below ambient temperature, the manufacturer says this is fine. Try cleaning the condenser out on the top of the rv. Gently hose the rear condenser out until all the dirt and grime is removed the unit. Try cooling again and see if it is better.
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
A/c doesn't remove moisture in the room? even when exchanger is set on open or closed--no moisture in collection tray either model #agj3211daxt2    G.E.
An A/C unit is a dehumidifyer BUT Unit are rated in Pints of water, a Unit in Florida might need a de humiditiyer connected to it, the air is heavy with humidity. Another reason is that the Unit is under sized or not allowed to run long enough (?) Infor. on what State you live in would help and the size of the apt. or house the unit is covering. The best T / H would be 70* and 55 H and that would be on the cool side for most people , avg temps in a house would be 74* 65%, body temps are 98.6 most A/C unit are rated at 90* amp temp ( outside ) if the condenser is dirty this will cut the performance on a hot day over 85* Keep unit clean -replace filter (s) . If your getting a 15 degree reading between outside and inside your doing good the best would be 20 degrees ( depending on heat load) windows, and sun. Actic fans remove 30% of the heat -it will drop the temp from 120 to about 85, this can save you a lot of money in A/C bills and help cool the house in warm day when you don't need the A/C.
Apr 27, 2009 | GE AGQ10AJ Wall/Window Air Conditioner
Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Mar 01, 2009 | Dometic RM2852 Refrigerator
Dometic RM2852 Refrigerator Logo
576 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
