Question about Craftsman 20 Hp 42" Deck Lawn Tractor
My Craftsman 15 HP Lawn tractor is spewing white smoke. When I removed the air filter, I noticed there was oil all over the inside of the air filter and at the bottom of the air filter. When I run the tractor without the air filter covered I see oil being spewed up through the hot air vent into the carb. What could be causing this?
  • oconnell2115 Jun 02, 2010
    Oil level is fine, the mower runs only on a flat lawn. When I hand try to turn the top of the engines crank case I get resistence and could feel the engine pull in air. Could it be a worn head gasket or a faluty crankcase breather?
On ours ,it was a bad valve seal on the intake valve.If you have a way to air-lock the cylinder, (so the valve doesn`t drop), you can make this repair without removing the head.
Posted on Jan 28, 2013
  • Dulley 39 Jan 28, 2013
  • 402 Answers
I could be caused by a couple things, the most common is overfilling with oil, running on too great of angle and flooding the valve stem area or really bad valve stem seals.
Posted on Jun 01, 2010
  • Mike Squire Jun 02, 2010
    It sounds like you are getting a lot of crank venting, take the mower to a dealer and have the compression checked, you may have some failed internal parts that are repairable if you don't run it too much more.
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Toro lawn mower
You may have overserviced the oil.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Oct 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
My lawn mower is spewing white smoke.
I had one in the shop that someone got their gas and kerosene cans mixed up and put kerosene in their mower it still had a little gas in it so it started up but had alot of white smoke if its blue I would tell you ,you over filled oil ,.
May 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
17.5 h.p. b/s craftsman tractor oil pushes into carb. smokes bad!
Make sure it's not overfilled with oil.
if this is not the case, then you have excessive blowby, which is what blows past your rings when the air/fuel mixture ignites. there is only one explanation for this, faulty rings, and that's what it sounds like to me. the blowby forces the oil into the vent leading to the filter, and back into the cylinder, where it burns, creating blue smoke.
Apr 14, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
514 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
