Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I need the part number of the drum potential sensor Y/M/C/BK for KM BizHub C6500
  • 44 Answers
65AA -909 1E
Posted on Jun 28, 2010
I have a Konica Minolta C6500 and I have error code C4717 what can be done
Index sensor output does not
change by the execution of
APC. Index sensor cannot
detect the laser because the
polygon mirror does not rotate,
or because of the index sensor
out of position or defective index sensor
Basically the (Black print head/LASER UNIT/Write Unit) for Black drum is causing problems internally. Inside the unit the Index sensor output does not change by the execution of APC. Index sensor cannot detect the laser because the polygon mirror does not rotate, or because of the index sensor out of position or defective index sensor. Or one of the many control boards is causing issues with Black Laser Unit, such as:
Printer control board (PRCB)
Image processing board
(IPB)
I/F board (IFB)
Image memory control board
(IMCB)
Serious Cost for these boards, recommend a Konica Minolta Tech check this out. Sorry
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 03, 2015 | Konica Minolta Bizhub Pro C6500 Printer...
How can i fix konica minolta bizhub c6500 error code c-2804
WHAT EVER YOU DO DO NOT PLACE ANY PRESSURE ON THE FOUR LARGE SHAFTS THE TURN THE DRUMS
Pull out the Drum and Transfer belt section. then from the right side gently clean the three sensors that site across from the belt. all three have metal covers BE CAREFUL they also have tiny springs don't lose them. Just lift them and clean the sensors with a dry rag. AGAIN do not touch those large shafts. if the cleaning them does not work remove the assy. two screws one connector. Don't lose the screws. Also clean out the Transfer belts cleaning blade unit remove hard toner remove the assy. and disassamble. Then run the gamma procedure in 36 mode.
Aug 19, 2015 | Konica Minolta Office Equipment & Supplies
What is Konica C6500 bizhub PGC sensor?
OK you going to open front door pull out mid section not where the paper is but where the drums and transfer belt are located. Once out go the right and look in DO NOT PUT ANY WEIGHT WHAT SO EVER ON ANY OF THE FOUR SHAFTS you will do some SERIOUS Damage!!!!!!!!!!!!!!!!!!!!!! So looking in there to the left you will see a assy. that is high up even with belt on the other side. That assy. as Three sensors one is your PGC two of thee sensor are in the front one sensor is in the back be care each has small spring that is used to pull the shutter down after the solenoid fires behind that assy. recommended that all three sensors be cleaned they get covered with toner from the belt cleaning assy. That hole assy. can come out to screws in the rear and one connector use a magnetic screwdriver and ensure power is off AGAIN NO PRESSURE ON THE DRUM SHAFTS!
Aug 07, 2014 | Konica Minolta bizhub Office Equipment &...
Reset error code c2833 on Konica Minolta c6500
cyan drum potential sensor bad or dirty or cyan drum need to be replace worse case print control board!!!
first try cleaning the sensor located behind each drum so remove the cyan one, it near the front looking at machine from the left side of the middle section, its a sliver/chrome looking with a tiny square hole use a clear brush mite as well remove them all do the same, should be done during 250,000 PM kit install. If not that switch drums, then switch sensor all the same, last control board $$$$$$$$$$$$$$$
Jun 27, 2014 | Konica Minolta bizhub Office Equipment &...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
I have c6500 konica minolta bizhub and i am getting c2452 code what i shouls do?
check the magenta developer unit, might need to replace the developer, also might have to replace the Toner sensor located under on the unit
Dec 28, 2013 | Konica Minolta bizhub C250 All-In-One...
Konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
134 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
