Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a Cub Cadet LT 1042 lawn tractor. The pto will not engage. What can i do to troubleshoot this problem?
4 Suggested Answers
  • 10865 Answers
SOURCE: Why doesn't my mower start on my 1042 Cub Cadet
The mower is activated through a vacuum system. There are two fuses under the dash. To get to them remove the hood and then pop off the plastic shield which protects the area under the dash. Check both fuses. Replace one if necessary.
Now, if that fixes your problem great, if not there is a vacuum relay that could be bad.
Posted on Aug 02, 2009
  • 6468 Answers
SOURCE: Cub Cadet LT1042 PTO
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
Posted on Jun 04, 2012
thenewfam
  • 6 Answers
SOURCE: White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
Posted on Aug 07, 2012
PTO TESTED ON MY CUB CADET LT 1042 WORK WELL BUT NOT ENGAGE .THE BELT NOT SPINNING
pto switch bad or clutch unplug switch look at plug if burn repacs switch if not clutch bad
Jun 02, 2018 | Cub Cadet Garden
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
My 1042 cub cadet lawn tractor blades will not engage
more often then not its the pto switch or a blown fuse
Sep 07, 2013 | Cub Cadet Garden
Jun 01, 2012 | Cub Cadet Street Sign- tractor lawn riding...
How does the PTO on a cub cader LT 1042 operate?
Sounds like the anti rotation bracket is not engaged in the side of the electro magnetic clutch, there will be a bracket or plate or bolt fixed to the chassis that engages into the outer edge of the clutch to stop the whole unit from spinning
May 15, 2012 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub cadet lt 1018 blade will not engage when i pull knob up
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
210 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
