Question about Haier ESA3087 Thru-Wall/Window Air Conditioner
Power surge/Control Panel
Window unit. Power surge occured this am. Panel will not work, no lights. Temp remains on 88, this shows, but cannot adjust. Have tried re-setting on plug. Fan works, no cool air.
    President:
  • 1,902 Answers
The control board blew. You will need to replace the control board on your unit and everything will work correctly again. When a power surge happens it will blow the weakest link, and if your system is not on a protected outlet then the weakest link is your control board.
Posted on Jun 01, 2010
My Samsung refrigerator rf266aepn has a display 88 88 where the top of the 8 on the 3rd 8 is flashing. What does this mean and is there any way to clear the code? Will not clear when shut the breake
Have you had a power surge lately, if so it may have damaged your control board. This is a starting point, I am not that familiar with that model. If that is true you may want to check with your homeowners insurance agent.
Dec 05, 2014 | Samsung RF266AEPN
Paykel dsc gse480ss panel shows 88 88
i don't work on this brand but from what you describe you have a bad mother board,when you unplug it that's what you are resetting,your model number doesn't show up so i can't give you a part number.
Nov 19, 2017 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Refrigerator control panel
88-89 Flashing Reverse 9.
I noticed this occurs when the Ice Machine get jammed up.
Remove all ICE from Tray and Clean.
Press and Hold Energy Save+Alarm Button for 10 Sec.
Jul 18, 2010 | Samsung Refrigerators
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Jan 23, 2010 | Samsung RM255LASH Side by Side...
Panel showing 88 88
You can try unplugging , wait a few minutes , and plugging back in . If that doesn't work , then the main control board , located on the back of the refrig ( behind an 8 " X 10 " panel ) , was damaged by the power surge , and needs to be replaced .
Nov 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Haier ESA3087 Thru-Wall/Window Air Conditioner Logo
348 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
