Question about Bose (321GS) System
DVD quits while watching a movie
While watching a movie my Bose 3-2-1 Series II stops. The picture is still there but the screen freezes as though I put it on pause. Sometimes it starts going again after a minute and sometimes it doesn't. When it stalls, I can not get to the menu or stop it. I have to shut it off and go to a scene which may or may not have been the scene I was watching.
  • Anonymous Aug 16, 2008
    My Bose 321 also stops mid-movie, the screen freezes and then "cannot read disc" message comes up. Often I have to unplug it and plug it back in to get it to open.
    Problem Solver:
  • 10 Answers
Have you tried cleaning your lens?
If so your dvd drive may be going bad
Posted on Apr 24, 2008
Connecting a turntable to a Bose 3.2.1. Series II
Bose 321 GS Series II DVD Home Entertainment System is a newly redesigned, sleek media center that includes a DVD/CD player, AM/FM tuner and inputs for three additional sources. The 3 2 1 GS Series II system now has even greater ease of use and setup. The 3 2 1 GS Series II system is for customers who want the benefit of home theater sound but would prefer the simplicity of two visible speakers, a hideaway Acoustimass module and fewer wires so they don't need to run wires to the back of their room. Media center plays - DVD video (including progressive scan formats), AM/FM, CD, CD-R, CD-RW, digital 5.1, and MP3 files on CD AM/FM radio includes 20 presets, scan and seek Three audio inputs with both analog and digital coaxial jacks, and one optical digital audio input, provide greater setup flexibility Dimensions - media center, 31/6H x 133/4W x 99/10D (8.02 x 34.93 x 25.27 cm); speaker arrays, 21/2H x 51/2W x 41/8D (6.4 x 14.15 x 10.52 cm);module, 141/2H x 83/4W x 191/8D (36.7 x 22.2 x 48.5 cm) Weight in carton - 44 lbs (20 kg) One-year transferable limited warranty
and from the review
Audio-input connectivity is a bit more robust. You can connect three audio sources through analog or digital jacks. The system is compatible with MP3 CDs and can decode Dolby Digital and DTS surround soundtracks from DVDs and external sources.
Bose 3 2 1 GS Series II DVD system review
May 14, 2017 | Bose Audio Players & Recorders
Dvd sometimes work and most time flicker
I suggest you call Bose. Most likely your disk drive needs to be fixed or replaced. In rare cases just updating the system with the latest software will help. Anyhow call Bose, they will fix it.
Mar 18, 2014 | Bose 3·2·1 II System
I hooked up the cords exactly as picture and when in dvd input the picture is in black and white. I tried movie the yellow video chord to every single hole on the back of my tv and it doesnt go to color??...
If you tried the yellow composite cable "in every single hole" it wasn't exactly 'exactly' following the manual then, was it?
Are you using component cabels, too (red, green and blue). Mis-wiring them will give you B/W or other wierd visuals.
Your TV's inputs and what is selected by the TV's controls would determine which cables' input it display. You could prove whether the composite is the culprit by removing it while viewing the TV. If the picture goes away, THAT cable is carrying the video you're watching. Otherwise, maybe you need to select the component input and check the conenction of each wire while watching.
Mar 18, 2011 | Bose 3·2·1 II System
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
We have a black rectangle appearing on TV when playing DVDs and can't get rid of it. We were setting up to watch a DVD, pushed some buttons inadvertently on the remote and ended up with menus that we...
it sounds like someone turned on the text box on the closed caption feature on the set there may be a button on the remote or look in the set-up features in the main menu
Techman.
May 16, 2010 | Bose 3 2 1 GS Series II DVD Home...
Bose GS 321 HDMI issue. I've had this unit for 6 months using the HDMI connection from the Bose to my HDTV for watching DVD's and its been working without issue. Last week I try watching a DVD. I change...
Hi, did you manage to fix it? I have the same problem. Would appreciate if you can share some results if you have any.
Many thanks, Jeffrey jeff@worldmail.nl
Mar 08, 2010 | Bose 321GS Series II System
BOSE 321 DVD movie movie picure is blue. Its connected to a Sony LCD digital Wide screen TV Bravia Model KDL 40V2500 and my cable box. Could it be a loose connection.
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
Oct 25, 2009 | Bose 3·2·1 II System
Bose 321 display is only Black and White..all movies too
Could just be the dvds? Or not...
Replace the laser that reads the discs!
Jul 07, 2009 | Bose 3 2 1 GSX System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
DVD Issues
firmware issue with bose i would call them to get dvd rom updated
Dec 27, 2007 | Bose 3·2·1 II System
Bose (321GS) System Logo
177 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
