Question about Ovens
We are not geting any gas at top oven lower oven is fine
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 01, 2010
Testimonial: "thanks will try it"
Oven will sometime take an hour to get to temp after being turned on. any thoughts?
If your oven is older or you live near the water check if there is a build up of fine rust over the burners. A fine wire brush lightly run over the top of the burners may be your solution. Before you attempt this disconnect electrical power and turn off the gas supply. If you are mechanical remove the front lower cover by opening the doors, removing the two screws located in the top of the lower cover next to the door hinges. The cover will remove to the front. Next remove the screws holding the shield in fromt of the burners. A long handled fine wire brush will allow you to brush the top of the burners. If there is a film of fine rust it will not be apparent when looking. After careful reinstallation of the burner shield and ensuring there is a safe area away from the exposed electrical connections for you. Reconnect electrical power and gas to the oven temporarily. This will alow the unit to be operated enableing you to look past the pilot flame to see if the burner flames are even across the burners. Disconnect electric and gas supply from the unit prior toiInstalling lower cover. After complete reassembly reconnect power and gas and enjoy.
Aug 08, 2011 | Blodgett DFG-100 Gas Single Oven
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Cannon camberley double oven the lower oven will not work and no gas is coming through to it but the top oven works fine can u help. Thanks Steve
Just got one today and have the same problem. Have read on here you need to set the clock to turn on the gas. Now i just need to figure how to set the clock.....
Nov 25, 2009 | Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Aogd2750e gas double oven
F1=Electronic range control failure
It is telling you may have a faulty control...need to replace control or EOC
Thanks
Dec 07, 2007 | Amana AOGD2750 Gas Double Oven
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
