Question about Frigidaire FRT18FS6C Top Freezer Refrigerator
Unit is running just not cold in fridge and freezer is warm
Only 3 years old
    President:
  • 3,113 Answers
It probably needs a defroster timer. You can take it apart and clean the contacts with some sand paper to fix the old one. It's located just behind the light bulb. You will have to lower the cover for the light to get to it. Defrost the top freezer by leaving it off for a period of time or take the shelves out and blowing hot air into the rear vents until ice melts. Then reinstall timer and plug back in. Get the whole model number and go to appliancepartspro.com to get a diagram. I fixed mine in less than an hour. frt18il6dw
Posted on Jun 02, 2010
5 Suggested Answers
  • 159 Answers
SOURCE: Whirlpool GB9SHDXP (freezer on bottom) fridge warm, freezer cold
low gas in the system
Posted on Jun 17, 2009
  • 2468 Answers
SOURCE: freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Posted on Apr 26, 2010
  • 157 Answers
SOURCE: Two year old Fridge with
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Posted on Jun 27, 2011
heatman101
  • 43501 Answers
SOURCE: fridge light on but fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 06, 2011
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
heatman101
Sep 05, 2011 | Refrigerators
Fridge temperature not correct and freezer items are all defrosting. This also happened a year ago, except it was just the freezer and the fridge freezer is only 3 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Beko Refrigerators
I have a Performa side by side 7 years old, had a repairman out because it started running constantly...Dx was there is a freon leak. Isn't this uncommon for a fridge that is not THAT old?
It happens alot in my 18+ years i have seen them leak 1 day later to 30 or 40 years later.If it was running and not stoping and freezer and fridge warm or hot it may be a leak if it runs alot and freezer is cold and fridge warm then it is not a freon leak.
May 18, 2010 | Refrigerators
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Feb 16, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Frigidaire FRT18FS6C Top Freezer Refrigerator Logo
186 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
