Question about Toshiba Satellite L45-S7409 Notebook
When i put the cd in it runs but the installation doesnt not come up do have any ideas how to set it up
  • 623 Answers
Go to the Windows button lower left open it, click MY COMPUTER in right hand column, look for your CD player, double click on it to open it.
Posted on Jun 01, 2010
HP DV6 Laptop... Running Vista 32bit. Trying to install microsoft office 2007. Instalation disc goes in, auto run begins and i click the install button. From there the installation process begins but then...
Check that, Is your CD has not faulty (You can check it on another PC). If yes change CD from your retailer & get new CD. If your CD is not Faulty they try to install & wait untill its work.
Thanks.
Oct 10, 2009 | Microsoft Office Professional 2007 Full...
CD Burner doesnt see a Disc is in already
ok..sounds like maybe your cd drivers are kaput...what computer are you using?
Mar 25, 2008 | TDK veloCD CD-RW Burner
Did fresh xp home install on ze2315us hp laptop. Everything was fine till xp started to do its updates. My cd is sp2 oem version. Now I get windows cant load missing windows/system32/config/system. Any...
  1. For the first problem, you'll have to run your windows installation CD in and choose repair installation.
  2. For your wireless among other things, run your drivers CD (its among the CDs you got when you bought your laptop).
  3. Run the drivers for wireless, sound...
  4. Enjoy your laptop again
Oct 05, 2009 | HP Pavilion ze2000 Notebook
I need to reformat my NEC e3100 because im experiencing all kinds of internet issues and software issues where my computer doesnt even recognise any programs installed. how do i go about resetting it. i...
To reformat usually you either use a windows install disc and reinstall windows, or you use a boot disk and a format utility, depending on the windows version. There are also format discs such as UBD that also work. When you format your drive, you lose all the information on it. You also will need a windows disc and serial number to install after a format.
The easier way to get your computer working is to simply use your windows disc to re-install windows. Before doing that it is a good idea to run several different virus and spyware scanners as well as a registry cleaner. RegScrubXP is a good one to use. When windows is running, simply browse to your windows disc and run setup.exe, that will reinstall windows over top the copy you have and replace any damaged or missing files. Then reinstall all your programs and it should all work. Programs can be re-installed over top even if they already are installed, basically all that happens is the missing files are replaced. Re-installing does not give you two coies of the same program - it just makes the copy that is already there work again.
Windows 2000 and XP have a feature for repairing also, in the start/run menu, type sfc /scannow and put your windows CD in, it will then check all files and replace any damaged or missing ones.
Aug 31, 2009 | NEC Versa VX Notebook
Diablo 2 problem
try clicking on the auto-run file in the CDs folder. if still you cant get it to auto-run or start installing clean the cd and make sure you have the install disc in not the play disc or the cinematic disc
Dec 11, 2008 | Vivendi Universal Diablo Battlechest II...
I keep getting error message when i try to install my mfc665cw all in one printer usb device not recognized has malfunctioned windows doesnt recognized
With any unresponsive USB devices in XP it is always a good idea to try removing the device first with uninstall, plug it into a different USB port, and then reinstall the setup software. (Preferrably using a version from the vendors home-site instead of the original CD.)
This will do two things:
  1. It will make sure that you are running the most up-to-date version of the installation software and driver.
  2. It will keep Windows from trying to "put back" the same settings that are causing you issues.
Jul 24, 2008 | Brother Office Equipment & Supplies
Oxygen8 v2
Well do u have the controller CD? Because I bought the MIDI board as well yesterday and found out that w/o that CD installed it won't work. But my problem is the CD won't install on my vista because its not "compatible" any ideas?
May 24, 2008 | M-Audio OXYGEN 8 USB Controller
Cd-dvd rom error code 10. failed to start
I had similar problems with my HP computer and i found either uninstall it through device manager the reinstalling it through new hardware wizaed in control panel. Or if that doesnt work try opening your laptop up and unplugging/removing the drive itself and restarting the laptop then turn it off again and put the drive back in the computer should then register it as a new device and reinstall it. that second option worked for my drive so it should hopefully work for yours
God Bless
Braydon
Mar 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Installing programs
You should have the cd's that came with the printer and scanner, put it in the cd or dvd drive it should autorun follow the online screen restart if necessary. if the cd does not autorun browse to the cd drive root there you will have the setup.exe or associated setup application just run it.
Jan 02, 2008 | Acer Aspire 5610-4648 Notebook
Windows freezes when inserting a cd
I had this happen to me with corrupted CD's, or just old scratched ones. If it's not specific, but happens with every CD you put in, then try the following- right click my computer>properties>hardware>device manager>right click on your burner drive>properties> You'll find a troubleshooting option there, and if you click on the driver tab you can also update the driver or roll back to a former driver. Let us know it it worked out(use the comment option), if not we'll try figuring something out ;] Good luck
May 27, 2006 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Toshiba Satellite L45-S7409 Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
