Question about Sport & Outdoor - Others
I have a 800 gal koi pond and was told to add rock salt to it to help control the algae. How much rock salt should be added , without harming the koi?
    President:
  • 1,194 Answers
The suggested level of salt for your pond water is 1.8 pounds of dissolved salt for each 100 gallons of water. You can buy a salinity meter for maintaining the pond water quality from this link.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on Jun 01, 2010
What happens if I put too much salt in dishwater
Hey Des,
I assume you're referring to the pool rather than dishwater. Adding too much salt won't necessarily do harm instantly. However, to some swimmer, the high salt content can be quite rough on skin and even hair. Aside from swimmer experiences, any masonry around your pool will erode quicker over time due to salt being extremely abrasive by nature. I'd recommend getting a salt tester strip or electronic meter to check your salt.
To add on, if the salt generator is constantly saying to add salt, it's probably time to clean your salt cell also.
Sep 15, 2017 | Pool & Spa
How do i get rid of frogs from my koi pond
Empty the pond for a week, keep the KOI n an alternative location.
The frogs will move on for the most part.
Second add a filter and a pump to the pond, this will eliminate and Mosquitoes and other such food source from there Appeal to the pond
Third, any tall grass should also be removed.
If you can't move the fish for a week, try fencing with a mesh netting around the pond, but make sure it is dug into the ground and at least 2 feet high, 3 would be better.
Also Snake repellant keep frogs at bay as well, but keep it far away from the Koi!!!
May 27, 2014 | Hunting
I have a salt water pool which with a robot cleaner has been brilliant for the past three years. this year taking the cover off, we leaked alot of dirty surface water in. with a lot of cleaning the water...
Check the Ph levels - if it is way above 7 then it is too alkaline and it promotes algae growth. Add acid to bring the Ph level down to 7. Also after adjusting the Ph level then add anti-algae solution.
You can also add shock chlorine powder to the water to speed up the process.
Jun 11, 2012 | Pool & Spa
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
How to I bring up my chlorine levels with my salt water generator? All other levels are in range. I have added the recommended amount of salt (310 lbs) for my pool size (5000 gallons). My pool was green...
You can cloud your water by adding chemicals that are incompatible. You will cloud the water if you simultaneously add a water clarifier and a chemical to inhibit the buildup of lime scale. You will cloud it if you simultaneously add chlorine and scale inhibitor. You will also cloud your water if you simultaneously add soda ash and a chemical to increase the hardness of the waterResources recommends sodium hypo, lithium hypo, dichlor or calcium hypo to superchlorinate water until it contains 10 parts per million (PPM) of free chlorine.
Jun 17, 2011 | Intex Automatic Salt Water System for ...
12500 gal pool began by adding 8 \ 40# bags of
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
When do i add fishes to the pond
you should wait a week to make sure that everything is stable in pond and add your fish, avoid too many fish and overfeeding them. enjoy your fish pond, i love them.
Apr 23, 2010 | Tetra Aquarem Pond Water Clarifier / Size...
LAST FALL IN EDMONTON CANADA WE HAD ALL KINDS OF LONG STRING GREEN ALGIE GROWING IN THE POND. STILL GREEN WHEN WE UNCOVERED POND THIS SPRING. HOW DO WE KILL IT OFF AND KEEP IT OFF THE ROCKS...IT EVEN SEEMS...
they sell algae killer for ponds and water nurseries and some pet stores that u measure a dose for pond size and add to water to clear up. if there are no fish and don't plan on having fish in pond add several gallons of bleach as cheap cure
May 11, 2009 | Aquascape Designs Ecosystems S.A.B....
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
