Question about Samsung SF-560 Plain Paper Laser Fax
Message open heat error
Open heat error what do i do
    President:
  • 3,085 Answers
Replace the fuser
Posted on Jun 01, 2010
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Open heat error what does it mean and How do I
Turn off your printer, unplug the unit. Then plug it back in and turn it on.
This error message means that the printer needs service. See the following URL for more details: http://www.xerox.com/office/PE120kb/,case=R1018019549
I wish that I could be of more help.
Apr 14, 2010 | Xerox PE120i Laser Printer
Getting open heat error message, what's the solution
hi i dont know why my printer is showing open heat error i dont understand please solve this problem
Jul 10, 2009 | Dell 1600n All-In-One Laser Printer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Open heat error
Most "Open Heat Error" messages are caused by a bad fuser. Order a new fuser from Dell.
May 22, 2008 | Dell 1600n All-In-One Laser Printer
Will not print due to OPEN HEAT ERROR message?
Will need to have fuser replaced, guestimation is 150-200 for fuser plus 50-100 to fit
Dec 01, 2007 | Samsung SCX-5115 Fax Machines
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SF-560 Plain Paper Laser Fax Logo
120 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
