Question about Whirlpool WTW6400SW Cabrio Washer
Any problems or recall info on Whirlpool Cabrio
Displays F indicator when trying to run a wash load
SOURCE: Whirlpool Cabrio HE washing machine
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
  • 1314 Answers
SOURCE: whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Posted on Mar 28, 2008
  • 726 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
hey there i had a search F then 1 flashes there is a primary control failure. Replace the machine control assembly my best bet would be to call a service center or repair guy to advise you further what to do or even fix it as this will be a ongoing stuff around for you and you dont need that
Posted on Sep 15, 2008
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Is this washer recalled
Chris, found no recall, but it is discontinued. ckeck the links below law suit and petition for recall.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool WTW8600YW Manual
whirlpool Do recall on the Whirlpool Cabrio Washer or refund
https://www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode/posts/356583827716099
May 01, 2016 | Whirlpool Cabrio 4.6 Cu. Ft. White Top...
I am alway getting the f1 code
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall!
Nov 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Unballenced on spin even when empty
It may come up an unbalanced load but it may a sensor that is on recall. I have a Whirlpool Cabrio top loader and after I start it it says F1 which is a sensor on recall and I have to restart it several times before it continues the load. Go to their web site and you can look up the exact model to see if yours has a recall as well.
Sep 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Every time I start the washer it stops and displays a F1
At first you can just cancel and start a few times and it will get it going for you.. However, Whirlpool has not put out for the public to know that there is a recall on the board.. Call whirlpool and let them know that you are having this issue and they will send a tech out, free of charge, and fix the problem... I just did this 2 weeks ago... Solved the F1 problem..
Jul 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirpool cabrio It works just for one minute and then it stops
Does the display say F1? Call Whirlpool at 800-659-7026 and see if you qualify for a recall upgrade of the control board. It's a very common problem.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on cabrio washing machine
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
  • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
  • I'll let you all know how it goes after the repair..
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine continues to display F1 and other F displays. Moved clothes around and pushed power which started machine again, but interupted again shortly afterwards with beeping.
There is a recall on this washer.
Please call Whirlpool...800-253-1301
There is a recall on the Cabrio Whirlpool washer for the F1 code.
The problem is the main computer brain - it is a common defect that whirlpool likes to keep quiet.
Hope this is helpful for you. There is, unfortunately, no end-user fix.
Thanks for using FixYa - a FixYa rating is appreciated for the time taken to answer your FREE question.
Mar 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
595 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
