Question about Polaroid Photography
How to elarge my old plaroid photo without using a scanner.As the scaner image is not ofgood quality
    Brigadier General:
  • 3,006 Answers
Polaroid images themselves are not very good quality, so your options are limited from the start.
Either use a better quality scanner or take photos of the Polaroid images. There are no other options.
Posted on Jun 05, 2010
Changing resolution for scanning photos to get top quality for printing
The resolution settings are included with the driver software. If you are using a graphics program to access your scanner, then you can change the resolution within the graphics program, usually by clicking ththe 'image' tab in your graphics program.
Sep 09, 2012 | Panasonic KX-MC6040 Multifunction Printer...
Canon MF3110 - Copy problems When we try to copy a document it comes our blurry, yet if we send a document from computer software it comes out fine.
Try reinstalling the driver first. If that does not work, the issue is with the scanning hardware, which will have to be calibrated. Try doing a calibration of your scanner from the tool box first. If that doesnt work either, then it is definitely scanner hardware defect.
If your all in one is under warranty, I'd recommend you contact the point of sale of the manufacturer. Unfortunately, if your warranty has run out, you will either have to get it serviced or buy a new machine (whichever works out cheaper)
Hope that helps!
May 26, 2008 | Canon Office Equipment & Supplies
Lines on printout of scanned image
The problem is with Scaner.
There will be any dust particle is on the purticular sport of scaner, try to clean the scaner.
If any one or more Photo Diode damage (Used in Scaner which glow) then also the problem will be
there.
Change the scanner if damege (Open the top lead and press copy butten then see any LED is off / not glow)
Jun 02, 2011 | HP Photosmart C5180 All-In-One InkJet...
How to reduce an mb while scanning
Hello if you want reduce Mb, you need reduce quality of the image when scanning. Check in properties of your scaner, or after scan reduce size of files by any photo editting software. If it help please rate it. Regards
Oct 12, 2010 | Computers & Internet
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
How do i connect my epson scanner 3490 t0 my epson r220 printer
i am not sure if the two could be readily connect. but, you may connect them on two of the USB port on your PC at the same time.
Oct 07, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Convert canon canoscan N640P EX to use usb
please the old scaner programmi is unstoll and you go a run and add a scaner progremme cd instolldrriver orignal and start the scaner is on
just you used the window xp if fouto didate and give a usb cable and use a scaner
Sep 22, 2009 | Canon CanoScan N640P ex Flatbed Scanner
Driver for mustek phto express
I have a mastak bearpow nagative scaner but i lost software. Thats why this scaner is useless. please give me software.
Feb 09, 2009 | Mustek A3 USB Flatbed Scanner
Need to know how to use the scanner on a lexmark 6500
You can change the resolution (dpi) of an image or of the copies you're making from the 6570. Here's instructions on how to do both:
Change the resolution of copies:
1. From the operator panel of the printer, press Copy Mode.
2. Press the menu button.
3. Press the arrow buttons until the Quality option appears.
4. Press the check to select Quality.
5. Press the arrows until the quality you want appears (you can't choose a specific dpi here, but you can adjust the quality).
6. Press the check to select it.
7. Press Start Color or Start Black.
Change the Resolution of an image:
1. Open Productivity Studio.
2. Click File > Open and select the image you want to edit.
3. Click Advanced.
4. Click Image Resolution/Size.
5. Select Photo Size to select from a list of defined photo sizes, or click Custom Size to enter a different size.
6. If you select Custom Size, type the width and height you want to use for the custom size.
Jan 19, 2009 | Lexmark X6570 InkJet Printer
Photography Logo
52 people viewed this question
Top Polaroid Photography Experts
luminos8
Level 1 Expert
danoyachtcap
danoyachtcap
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
