Question about Xerox CopyCentre C20 Black and White Copier
Open Heat Error
Message in the display :
Open Heat Error
    President:
  • 3,085 Answers
Replace the FUSER UNIT
Posted on Jun 01, 2010
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
Open heat error message displayed
you have to replace heater roller unit .problem is your thermistor wire is expired. replace it.
Feb 08, 2011 | Samsung SCX-4216F All-In-One Laser Printer
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
There is display message that open heat error & nothing is printing
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 05, 2010 | Xerox WorkCentre PE220
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What is open heat errot
One of two things, both will require a fuser replacement.
Either the over hear thermostat has open, or and most likely the heating element built into the heat roller has failed. Normally the heating element burns out and displays that message, I have not found that roller assembly spared, and even if you try and swap one from a used fuser to new, they are really dificult to change because of the spring end contacts.
In simple terms, replace the fuser and you will fix the problem.
Mar 28, 2009 | Xerox CopyCentre C20 Black and White...
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error F10
There is a topic alryde about the F10 error
You will get your answer here
http://www.fixya.com/support/t1461650-wf840_f10_error_code_get_worse
Good luck to you!
Please take a moment and rate my answer
Nic
Feb 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Xerox CopyCentre C20 Black and White Copier Logo
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
