Question about Google Computers & Internet
How can we make 37 by using five 5s? - Google Computers & Internet
    Scholar:
  • 71 Answers
(10/5)^5+5 = 2^5+5=32+5=37
Posted on Jun 05, 2010
How do I remove the back of the 5s so as not to damage the phone Iam new to iphones
You need the correct tools, a five sided 1.4mm screwdriver and vacuum pliers.
Aug 19, 2017 | Cell Phones
Own an iPhone 5s. Just bought Google Home. iPhone 5s has 16GB and Home wants 24GB. Is there a way to upgrade the 5s to meet Home's requirements?
no there is'nt any upgrade for that because it is factory fixed. buy a new iphone with a 32GB to meet your home's requirements.
Jun 30, 2017 | Google Cell Phones
How do get deleted messages
I do not think you can but the best thing is to call apple there help is great and free.
Dec 10, 2014 | Apple iPhone 5
How to restore lost call number from iphone 5s ?
You cannot restore/recover a deleted call record on the iphone .
May 12, 2014 | Apple iPhone 5S
Can the iPhone 5S be mirrored to atv with audio ?
Yes, the iPhone 5S can be mirrored on your Apple TV congruently with audio sound. Taken from Apple iPhone 5s Technical Specifications :
"AirPlay mirroring and video out to Apple TV (2nd and 3rd generation)"
Jan 31, 2014 | Apple iPhone 5S
I cannot open my i phone 5s becauase somebody used an apple id which i dont know ho will i open now my iphone 5s?pls help
you can try going into settings then 'about' click on reset my phone and make a new one or when you put in your sim connect to a computer and sync with itunes to make a new account
Dec 26, 2013 | Apple iPhone 5S
What is the Touch ID feature in the Apple iPhone 5S for?
The Touch ID feature in the Apple iPhone 5S detects the iPhone owner's fingerprint and uses it kind of as a password, unlocking the phone and allowing purchases.
The more the feature is used the better the phone detects the fingerprint. The system can detect the fingerprint from different angles and rotations.
Sep 11, 2013 | Apple iPhone 5S
I am a little paranoid about my personal information. Is the fingerprint scanner on the iPhone 5s optional?
You don't need to use the fingerprint scanner on the iPhone 5s if you don't want to. Instead, you can choose to use your four-digit PIN number or to not use any password at all.
1996 toyota camry 2.2 5s- too manny timing marks crank shaft,cam shaft and cam shaft gears
Hi there:I dont have this diagram for 2S-ELC, 3S-FE and 5S-FE Engines, but pay attention at this...
To install:
  1. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  2. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  3. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly.
Remove any oil or water on the idler pulley and keep it clean.
  1. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  2. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  2. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  3. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  4. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  5. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt.
On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  1. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  2. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  3. Install the timing belt and check the valve timing as follows:
    1. Align the matchmarks that you made previously, and install the timing belt onto the camshaft pulley.
    2. Loosen the No. 1 idler pulley set bolt 1 / 2 turn.
    3. Turn the crankshaft pulley two complete revolutions TDC to TDC. ALWAYS turn the crankshaft CLOCKWISE. Check that the pulleys are still in alignment with the timing marks.
    4. Tighten the No. 1 idler pulley set bolt to 31 ft. lbs. (42 Nm).
    5. Make sure there is belt tension between the crankshaft and camshaft timing pulleys.
  4. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  5. Install the spark plugs.
  6. Install the right mounting insulator with bracket. Tighten the bracket bolts to 38 ft. lbs. (52 Nm), insulator nuts to 38 ft. lbs. (52 Nm) and thru-bolt to 52 ft. lbs. (71 Nm). On the 5S-FE, install the No. 2 engine mount bracket and tighten to 38 ft. lbs. (52 Nm); install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm).
  7. Lower the engine.
  8. On 3S-FE and 5S-FE engines, install the alternator and alternator bracket. On 2S-ELC engines, install the power steering reservoir tank.
  9. Install the drive belt and adjust the tension.
  10. Install the cruise control actuator with bracket.
  11. Install the fender apron seal and right engine under cover.
  12. Install the right front wheel.
Hope this helps.
Jun 12, 2012 | Toyota Cars & Trucks
My DVDXCOPY Platinum will not activate after inputing the License ID# and Password. Can anyone help please?
DVDXCOPY has been shut down for many years, their are a few people still selling it knowing it can't be activated. Their were a few sites that carried activation codes that worked. In all reality its not a very good program, I started out using it and switched to DVDFAB Platinum and haven't found anything it wouldn't copy, it also shrinks long movies to fit on a 4.7 DVD.
Aug 19, 2009 | 321studios DVD X Copy Platinum (200000)...
Computers & Internet Logo
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
