Question about Jenn-Air Ovens
Oven will not ignite. - Jenn-Air Ovens
  • 360 Answers
Make sure that the oven burner is clean near the ignitor and there are no blocked gas vents.
There also has to be gas flowing over the ignitor for the oven to light. Also, check the positioning of the ignitor relative to the burner. It's also possible that the ignitor is not getting hot enough.
Take care.
Posted on Jun 01, 2010
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Replace igniter part # 1990 in oven of model #3627332192
It's usually pretty simple. Start by turning power off to the oven - unplug it or disconnect power at the circuit breaker. Open oven door, remove all racks, then remove oven floor panel (it might be secured with two bolts or clips on the back side). Remove the flame spreader (one nut). Now you have the oven burner and igniter exposed. If the new plug differs from the old, cut off the plug and use ceramic wire nuts (should be supplied with igniter) to connect the wires. Don't shake the igniter - the coil is very fragile. Once the igniter is replaced make sure the wires are connected securely. Put everything back the way it was and test the oven.
Below are the two most popular oven igniters: flat bar igniter and round igniter.
Flat igniter - this is by far the most commonly used oven igniter. Includes all necessary pieces to replace longer ceramics. Size: 3-3/4" long. Fits Maytag, Whirlpool, KitchenAid, Magic Chef, Tappan, Jenn Air, GE (flat bar only), Sears Kenmore (flat bar only), even some Thermador cooktops and Viking ovens. - ff693fe.jpeg
Feb 25, 2010 | Kenmore Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Hotpoint lp gas range Mod# rgb532bea5wh. Oven will not light. Igniter does work but no gas is passing thru the oven control valve. I replaced the oven control valve but oven still does not work. what else...
    -- defective pressure regulator(likely issue if the igniter is ok)
    Oct 23, 2009 | Hotpoint Ovens
    My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
    -- defective gas valve coils
    Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
    The lower oven ignighter does not glow
    I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
    FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
    Jul 20, 2009 | GE JGRP17 Gas Single Oven
    Oven/Broiler Igniters for KitchenAid range KGST307
    Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
    Dec 09, 2008 | Ovens
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    GE Oven does not ignite, bute Broiler does.
    Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
    Oct 14, 2017 | GE JGRP20 Gas Single Oven
    Stoves 900GRa spark ignition
    i have a 900g stoves oven how do you change from auto to manual
    Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
    Ovens Logo
    20 people viewed this question
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
