Question about Element Electronics EDBCO11 Blu-Ray Player
Need a manual for Element Bluray -EDBC011 - Element Electronics EDBCO11 Blu-Ray Player
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
I've got aspire z5801 .looking for a manual and softwhere to work the bluray.it works on normal DVDs but not bluray do I need software
Did the Blu-Ray drive come with a manual or drivers?
Normally, you need software (Nero, etc.) to burn DVDs. What are you using to access DVD drive successfully? What error message(s) are you getting?
Thanks,
Make a great day!
Roger
Jul 21, 2015 | Acer Aspire Z5801 All-In-One Desktop PC...
I have a element t.v and the remote but I have a Magnavox bluray but no remote how can I program my element remote to work with the blueray
You should first find out whether the remote control you have [for Element TV] have setup codes to set with the Magnavox Blu-ray player. In fact, with no remote control, you can't set up the Blu-ray part of the player, but if you have set-up code to your Bluray brand, You can set it up to control the DVD and CD regions.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Televison & Video
Sorry you can't, you will need to purchase a universal remote. This will allow you to control both devices from the same remote.
Need a replacement cord for edbc011 ..where can i find
Power cord is not a critical component to select. Just select one of good quality. That is all. You can buy it from most of the electronics spare part selling shops at your town. Keep the old power cord with you as a sample. If you have no power cord at all, just go with the player, to select a suitable power cord.
Jun 20, 2012 | Element Electronics EDBCO11 Blu-Ray Player
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
SONY REMOTE TO A ELEMENT TV CODES
Element TV ELEFT422 can be controlled by Sony BluRay Player remote model # RMT-B118A by entering the code 04 (same as Goldstar and LG TVs)
Sep 22, 2011 | RCA RCR311B Remote Control
I recently purchased a Blu-Ray Disc Player from Office Depot. The brand name is Element Electronics (model number EDBC011). It plays everything but blu-ray discs. The DVD player asked me to download a file...
I had the same problem with the blu-ray player and fixed it with the downloaded files. When you download the files they come in a folder called 'firmware_update'. Did you make sure you only put the 16 files that are inside this folder onto the CD and not the whole folder? It won't work if you add the whole folder. The update on the blue-ray player takes up to 15 minutes. You have to be patient.
Hope this helps:-)
Jul 29, 2009 | Element Electronics EDBCO11 Blu-Ray Player
Element Electronics EDBCO11 Blu-Ray Player Logo
69 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
