Question about Dell Dimension 3000 PC Desktop
How do i replsce the sound card on dell dimension
How do i replace the sound card on dell dimension 3000 and where is it located
  • Dell Master
  • 5,660 Answers
The Dell Dimension 3000 comes with Integrated sound.
This is Dell Support, and the Technical Specifications page for the Dimension 3000,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/specs.htm#wp1075776
Scroll down to the subheading - Audio
"AC'97, Sound Blaster Emulation, ADI 1980 audio controller with 2.1 implementation"
It isn't a sound adapter card installed into an expansion slot.
It is a chipset soldered to the motherboard.
Should you wish to install a sound card, (Sound adapter card), it will go into one of the PCI expansion slots. (White in color)
Technical Overview>System Board Components,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/techov.htm#wp1061217
The System Board is also referred to as the Motherboard, or Mainboard.
Looking at the illustration of the motherboard, the PCI slots are shown to the right.
Three long white slots that are vertically arranged.
PCI card slots (3) (PCI1, PCI2, PCI3)
This is a better look at a PCI slot,
http://en.wikipedia.org/wiki/File:Asus_a8n_VMCSM02.jpg
The two long White slots towards the top of the motherboard, are PCI expansion slots.
Doesn't matter which PCI slot you use, as long as it's open, and available. (No expansion card installed in it)
This is one example of a sound adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4459743&CatId=107
Would like to advise;
1) Work on a table when working on a computer.
A bed, couch, or directly on a carpet floor are High areas of Static electricity.
2) Your body carries Static electricity.
Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer unplugged from power, computer case open, TOUCH the metal frame.
Should you get up in the middle of working on your computer, and leave; upon your return be sure to Touch the metal frame again.
Follow the instructions given with the Sound card.
The sound card comes with a CD disk which should be used.
Should you have any questions concerning this, just post in a Comment.
Posted on Jun 01, 2010
  • joecoolvette
    joecoolvette Jun 01, 2010
    Install the CD that comes with the sound card FIRST, THEN install the sound card. The CD contains THE Drivers for the sound card.
    [Computer on, Windows loaded. Put the CD disk in the optical drive. {CD/DVD drive}
    Follow the instructions.
    Now shut the computer down normally, {Start>Turn Off Computer>Shut Down}
    Unplug the computer from power, open the computer case.
    Observe anti-static precautions.
    Install the Sound card
    Close the computer case, plug the computer back into power.
    Plug the sound system into the appropriate ports on the back of the sound card
    Turn the computer on ]
    Thought I would also include the Service Manual for the Dimension 3000, from Dell Support,
    http://support.dell.com/support/edocs/sy...
    Sergeant:
    Champion:
  • 357 Answers
The sound card is on the mother board, but you can buy a PCI sound card and install it in one of the empty whit slots on the mother board.
I am not sure but you may need to dissable the onboard sound before you install the add in replacement sound card.
You can ask dell support if you need to do this, www.support.dell@dell.com
Good luck. I hope this helps. Have a good day.
Replaced video card in Dell Dimension 3000 with NVIDIA GeForce FX 5500. Can't find video controller driver
Hi.
Click on the link below and download the driver for the card, if you are unsure then click on the Supported Products tab and you will see that the FX 5500 card is supported in the download.
http://www.nvidia.com/object/winxp_175.19_whql.html
Regards.
Feb 04, 2013 | Dell Dimension 3000 PC Desktop
I need a new sound card for my Dell Dimension 3000 Where do I go , how much will it cost and how do I install one?
u can purchase from any local store go for creative sound card pci slot if u r in blore call 9972888885
Sep 06, 2010 | Dell Dimension 3000 PC Desktop
What is the procedure for replacing the rear usb ports on a dell dimension 3000
USB ports are connected directly to motherboard so replacing them is not so simple because it is multilayer motherboard and you need special tools.
I think best solution is for you to byu PCI usb card or PCI USB card with firewire.
Apr 13, 2010 | Dell Dimension 3000 PC Desktop
No volume on my dimension 3000 desktop
Try to reinstall the sound card driver. You can download it from the following link: http://supportapj.dell.com/support/downloads/driverslist.aspx?c=hk&cs=hkdhs1&l=en&s=dhs&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=ck&catid=&impid=.
Feb 11, 2010 | Dell Dimension 3000 PC Desktop
Dell computer: Dimension 3000 clock battery needs replacement
it looks like a watch battery, usually about the size of a quarter.
Aug 17, 2009 | Computers & Internet
Replacing a sound card for a dell dimension 3000
Check if your PC has a PCI slot. It is this white strip on you motherboard. Go to your PC shop and ask for a PCI sound card. Just insert it and install the Drivers CD. If it doesn't, You may have the old ISA slot and stores may not be available of any ISA sound card. But dont worry, generally all computers starting from pentium 2 has a PCI slot. You may worry only if your computer is as old as the 486 computers.
Oct 22, 2008 | Dell Dimension 3000 PC Desktop
Vista Driver for Dell
use the dell website
www.dell.com
Apr 10, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
CARDS FOR Dell Dimension 3000 PC Desktop
Dimension 3000 accepts only regular PCI cards according to the Dell site.
Dec 24, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
263 people viewed this question
Alun Cox
