Question about HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner
I have no idea what I am doing. I put in a sata driver on my ide motherboard. I bought and hooked up all cords to connect it and now it only opens and closes. It will not install or read any disc. What should I do?
    Scholar:
  • 77 Answers
Thank you for your question.
The fact that it opens and closes means you are very close in getting it to work correctly.
Could we take a moment to sort out the technical aspects of what you are asking/saying?
Sata Driver on IDE Motherboard?
A driver is software that is installed to the Operating System. Do you mean a SATA Converter, so that the IDE connection is changed into a SATA connection? If so, let's move on.
The cords that you connected, is it two (usually)red cords with single black ends at each end? If so, let's move on.
If we have got this far, you will have to enter the BIOS settings to ensure that the motherboard has found your new DVD. If you have your manual it will explain which button to push on initial bootup to enter BIOS. It can be "delete", "F2 or F12', manufacturers are not consistent on this. Once in BIOS you need to make sure all options for the IDE drives are on "auto", makes the BIOS do the work for you.
You do not have to install the DVD, the BIOS recognises the new Drive as a Storage Device like a Hard Drive, no drivers needed.
Although the other thing after successfully getting the drive to read discs is you will need to install the optional programmes such as Power DVD for watching movies and Nero for burning DVD?CD's.
Kind regards
Posted on Jun 01, 2010
Should the sata cable be hooked up to the cd drive or the hard drive and where can i find pictures of where the inside cables should be attached to
One end of the Sata Cable is to be attached to the CD/DVD (Optical Drive) or Hard Disk, whereas the other end is to be attached to the motherboard. The Sata connections on the motherboard are located near the CMOS/RTC Battery as indicated below: - (Blue, White, Yellow and Black, at right-hand top corner)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | HP Pavilion a1540n PC Desktop
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Can You Put Windows On A 1TB internal Hard drive
If your motherboard has both connections you can have both (IDE and SATA) working together
Depends of your motherboard features.
Oct 07, 2008 | ASUS A8N-SLI Motherboard
SATA Hard Drives
coonnect your sata connection to hdd and aslo its other side to motherbord it is nesar the ide connector.
Oct 01, 2008 | Mach Speed VENOM V2DP Motherboard
CD-RW not working on same Ide cablew as HD
Hi, please check the power connector to the drive. if it is ok, restart the pc, enter BIOS setup, check whether the drive is detected or not in the drive configuration. if not there, check the jumper settings once again. for the new motherboards with one IDE and SATA interfaces, jumper settings are important. once i had the same problem.
good luck
Jun 22, 2008 | Computers & Internet
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
