Cold water fills the tub even when machine is not
After having the faucet fixed in my laundry room, when I turn on the cold water spicket, cold water fills the tub even when machine is not on.
  • 159 Answers
This is almost definatley the inlet valve faulty.The inlet valve is literally stuck in the open position.You will need to change the inlet valve.I hope this helped you.
Posted on Jun 01, 2010
Why does my washing machine take so long to fill?
Check to see if the screens are clogged on your water inlet valves. Just turn your water off at the Hot and Cold faucets, then remove the water hoses from the back of the wash machine.
The section that the hoses were attached to on the back of the wash machine is the water inlet valve (or valves). Take a flashlight and inspect for blockages on the screens (they're located right in the valve inlets).
If you see grit or calcium build up, you can usually pull the tiny plastic screens out with a pair of pliers and clean them out under running water. Then, put them back in and hook everything back up. Turn on your Hot and Cold faucets and see if your washing machine fills faster.
It should work, but if not, you'll need to replace the water inlet valve (or valves, depending on your model)
Oct 15, 2014 | Frigidaire Washing Machines
The water will not go into tub, keeps overflowing and flooding my laundry room
If the water will stop filling when you stop the machine, then you need to replace the "pressure switch" on the unit. Here is the part to order.
If you have to turn the water off at the faucet to get it to stop filling, then you need to replace the "water inlet valve" on the unit. Here is that part to order.
Nov 09, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washer is flashing LF
LF error code indicates that there is a water supply problem.
Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked? Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe? The drain hose may be too far inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shaped drain hose form as described in the Installation Instructions will provide the appropriate length of drain hose in the drainpipe or laundry tub.
Check it and keep us updated. remeber to rating this free answer and leave some testimonila comment.
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio WTW7600 model, error code LF comes, checked water pressure and it is ok. Help
This LF error code indicates that there is a water supply problem. Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
Is the drain hose taped onto the drainpipe? Is the top of the drainpipe covered with tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure the top of the drain is at least 39" (99 cm) high (as measured from the floor). If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction, (siphon) and the water will continue to drain out of the washer.
To remove the error display, press Pause/Cancel once.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Hope this helps (remember to rate this answer).
Jun 28, 2011 | Whirlpool WTW6400SW Cabrio Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Samsung WF337AAL Front Load Washer
Erratic water flow and temperature from laundry tub faucet..
this is quite possible, the newer units, actually are monitering teh watertemp, as it enters machine, and will either increase or decrease flow of both hot/cold water to maintain what it would consider an optimal temp.. so i would not worry about this issue.
Feb 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Cold Water Solenoid Problem
The fill switch has a diaphragm that could be damaged and not closing properly. I have personally experienced this problem before. The way water could be getting by the switch (even with no power applied) is simply water pressure in the lines. I don't understand why it would work during the spin and rinse cycles, however. If you say it's not a pressure switch problem (level sensor), then I would invest in a new fill valve. I hope this helps.
Jul 08, 2007 | Hotpoint VBXR1070W
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
