Question about WEIDERFITNESS.COM Weider Platinum Plus
Will not adjust weight - WEIDERFITNESS.COM Weider Platinum Plus
    President:
  • WEIDERFITNES... Master
  • 832 Answers
Plug the indicated end of the Transformer into the Rear Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformer when using the resistance system.
Then, press and hold the NEXT button and the motorize resistance + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, and then press the MOTORIZED RESISTANCE + button; this will start the recalibration process. This may take a few seconds as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120-volt outlet.
If you cannot hear the motor reset it self or cannot see display then with multi meter check DC voltage if not replace transformer , if you have DC voltage you will need to remove the cover locate the motor assembly disconnect the assembly from the upper electronics. Then apply a 12v DC voltage to the motor and see if it engages easily if not then replace motor. If motor functions properly replace connector back on the motor and use a multi meter connect it to motor and plug in the transformer and you should see DC voltage going to motor if not replace upper console.
Posted on Jun 01, 2010
Loose stitches when using zipper foot.
If it has been a while since the needle has been changed, doing so may be helpful. Also be sure to use a sharp needle that will more easily penetrate the zipper tape.
Be sure that you are actually lowering the presser foot before stitching (this most likely isn't the case--just a thought).
Most machines also have a presser foot pressure adjustment that can be loosened or tightened to accommodate different thickness of fabric and the amount of pressure applied by the zipper foot on the fabric and the feed dogs. Experimenting with that pressure adjustment may be helpful.
Some bobbin cases also have a finger extension with a hole through it. If you are experiencing issues with bobbin tension, sometimes threading the bobbin thread through that finger will help even out bobbin tension.
Using lighter weight thread will also affect the resulting thread tension. If the bobbin case is wound with light weight thread, the bobbin tension will not operate the same as it would with standard weight thread. Light weight thread in the bobbin will cause looser tension, but heavier thread will cause a tighter tension.
Technicians use a standard weight thread to test tension on a machine, but if you use a different weight thread, then your results most likely will not be the same.
Bobbin Tension How and Why Tension is Adjusted
How can properly adjust my tension
Understanding Thread Tension Threads
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=12&cad=rja&uact=8&ved=0ahUKEwiBnuWi4tnLAhXBtIMKHRRPA5gQFghPMAs&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q
Most tension adjustments can be accomplished via the upper tension. However, there are times when the bobbin needs to be adjusted. Sewists are frequently nervous about adjusting bobbin tension. It is important to mark with permanent marker where the skrew-slot is positioned on the bobbin case BEFORE attempting any adjustments (at least if you need to return it to the original setting, you'll know where it was). Make only 1/8 turn adjustments at a time and re-test. (Righty-tighty, Lefty-loosey!) Sewists who frequently use different weight threads in their machine will often have an extra bobbin case that is set up specifically for that thread weight so they don't have to manipulate the bobbin case every time a thread is changed.
Mar 24, 2016 | Juki DDL-8700
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
I have a 2003 flstci and I'm trying to adjust the rear shocks. Do I take the weight off the back tire or leave the weight on the back tire to adjust them.
The bike should have both wheels on the ground when you adjust the shocks. If you're adding weight to the bike, you can still adjust the shocks with the additional weight onboard but the adjuster will turn easier if the extra weight is not there.
Jun 26, 2011 | 2003 Harley Davidson FLSTC Heritage...
Need to adjust stylus pressure on my akai ap-a101 turntable
Not sure exactly with this one looked at a googled picture. The counter balance weight needs to come forward toward the stylus to increase weight and move back to decrease. there looks to be a thumb screw on the right of the counter weight turn anti clockwise slightly one of three things will happen either the weight will start to move down the arm, the screw will undo the weight will come loose and can be moved forward or back on the arm or not very much at all will happen at all.
Best to mark the position of the weight first so you can return it to its original position after you over adjust and cut your own grooves in you cherished vinyl only a small adjustment is required. failing that put a small piece of blu-tack on the top of the cartridge only joking.
Feb 24, 2011 | Audio Players & Recorders
Won't go in the shallow end. How to adjust
The hose weights for these pool cleaners just snap on to the hose. If you need to know where to put them, follow the following recommendations from the users manual. The pool cleaner should site at a 45 degree angle for the pools floor while resting. In general, if you have model# W03000, you will probably need one hose weight in the middle of the first section of hose. If you have model #W83215 or W83216, put two weights onto the middle of the second hose section. You may need to adjust the weights slightly to make sure that you get the cleaner to the desired 45 degree angle.
Jul 21, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Record keeps skipping arm won't move toward center of record
Sounds like your arm is tracking too light. To proper set the tracking weight on most units you need to zero the arms balance so that it is balanced just at the surface of the record. Once that is done using the weight on the back of the tone arm, or whatever system your unit uses, there should be an adjustment by turning the weight on the arm or perhaps a lever near it. You owners manual should really explain all this and give the recommended tracking weight in grams and fractions of grams. Each weight is different for different styli. Take a look at your operation manual and adjust the weight. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 22, 2010 | Numark ttUSB Turntable
Can I adjust the weight on the scales to match my doctors scales. Mine weight 6lbs less.
Adjusting the scale is not a solution but adjusting your weight all in 60 days.
No strees, side effect or bitter drinks but all natural flavour beverages. Tested & trusted ISO 22000-2005.
YES U CAN, ITS BETTER TO BE ON THE SAME PAGE WITH YOUR DOCTOR.
Oct 13, 2009 | Taylor & Digital Scale Lithium Scale
WEIDERFITNESS.COM Weider Platinum Plus Logo
932 people viewed this question
Top WEIDERFITNESS.COM Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a WEIDERFITNESS.COM Exercise and Fitnes Expert? Answer questions, earn points and help others
