Question about Philips 42PF9630A 42 in. Plasma Television
The TV will not power on anymore. It tries but
The TV will not power on anymore. It tries but only starts to click and the red LED on the front flashes.
    Sniper:
  • 67 Answers
What you have wrong with your tv is in the power supply board, it is a very common problem which you can fix yourself for around $30 this is a MAJOR Samsung problem and thousands of people are having this problem. What you need to do is deenergize your tv and lay it face down on a table so you can work on it. Use a philips screwdriver to remove all the screws on the back cover of the tv make sure to remember where they go for when you put it back together. Remove the back cover and follow the two wired from where your tv power cord comes in and in the middle of your tv they will plug into a board, this is your power supply board. Look for blown capacitors, also check the fuses the tops will be bulging upward and caps have writing on them like 10v 1000uf or 2200 uf and 3300uf are the most common. What you will need to do is replace these with a 16v cap but be sure the uf number is the same, and you need 105 degree rated caps. There is also a negative side to the capacitor which is marked with a stripe and a shorter leg on the bottom, these have to go in the same way or you will blow the board, remove the board with screwdriver and disconnect all wires, now you will need your tools solder, soldering iron, and preferably a solder ****** to remove the old bad caps here is a youtube link that shows u step by step just go there and type samsung power supply repair, and whether you have a vizio, philips or another model that this is posted on they all have samsung power supplies in them so if you are having power problems this is your fix, you should be able to get all your parts at radio shack or on the web. Thank you and votes are welcome and if you cant find the parts get to me and I can help you get them
Posted on Jun 02, 2010
TV kept going off and then comes back on in 2 or 3 minutes. Now it just wont come on. ?????
Posted on Aug 30, 2010
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
No picture or sound. LED blinks 5 times
Hi, I have a similar problem with mine. but mine doesn't cut out. I tried keeping my finger on the reset button, on the remote control, and shut the TV off. When I put it back on, it's not flashing anymore. So far, it's about 4 hours and it's not flashing yet. Hopefully it will not. It's worth a try. Hope this helps.
Dec 08, 2006 | Sony KV-36FS17 36" TV
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Philips 42PF9630A 42 in. Plasma Television Logo
725 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
