Question about Sony KP-51WS500 51" Rear Projection Television
Tv stuck in standby/timer mode blinking and will not turn on
  • bseay Jun 01, 2010
    My sony projection 51 inch screen will not turn on I have blinking light on timer/standby that blinks in a 6 sequence.
    thank you
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the no# of blinks standby timer light is flashing so that I can assist you further.
Thanks
Rylee
Posted on Jun 01, 2010
  • 5 more comments
    blinking 6 times per sequence
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    I am not a repairman and I have no idea what those numbers mean. Electronically challenged. Any ideas ?
  • Rylee Smith
    Unfortunately there is no other way to reset this issue, if you contact a professional the cost to get this repair will be around $250-$300 depending on the parts that are replaced. Please do accept the solution if the issue is resolved or
    Thanks
    Rylee
  • Rylee Smith
    I have already advised you what needs to be done, please post back if you need further assistance or accept the solution if the issue is resolved.
    Thanks
    Rylee
    rylee, what am I am I checking for on these numbers? I can find the numbers but what am I looking for?
  • Rylee Smith
    As I said you'll have to open the back of the unit and test the board with a voltmeter, then check the ICs that I advised you. Please do accept the solution if the issue is
    Thanks
    Rylee
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Stuck timer
my acoustic solutions tv is stuck in standby mode its the timer because it com on the other day how do i turn timer off
Jan 02, 2014 | Electrolux Ovens
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
The tv starts to come on,then goes of and the
off the sleep,standby timer mode on your TV.. you just check all the timer then turn it off.
Mar 27, 2010 | Televison & Video
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Standby mode and can't get tv to work
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Thanks,
Dan
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Sony KP-51WS500 51" Rear Projection Television Logo
216 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
