Question about Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision
RIPD CAMERA WIRES!!!
MY CAMERA GOT RIPED OFF THE WALL NOW I HAVE A CAMERA WITH VERY SHORT WIRES AND I WAS WONDERING HOW CAN I REWIRE IT STRATE TO MY TV IT HAS 4 WIRES (1 RED, 1 WHITE, 1 YELLOW, AND 1 THICK BLACK ONE)
  • Anonymous Mar 24, 2014
    I only have the wires that come out the back of the camera
    Problem Solver:
  • 9 Answers
You need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Posted on Jun 05, 2010
Oven trips circuit breaker
Dear Ralph,
I am extremely happy you have asked this question, and here is why.
I am a retired Fire Chief, and I should like to ask you to NOT use the oven, stovetop, or range until it is repaired, as there is ever reason to assume you are about to have a fire.
The last one of these that I repaired had a defective ground wire, and required only a rewired wall socket to fix the problem.
The steps will be to unhook the range, stove top, and/or oven, and check the wiring in the back of it, first the wall socket (take it apart).
If that is good, then take the range , etc. apart until you find the short circuit.
It may be a burnt wire, a wire that is shorted out, or a defective control unit.
God bless your efforts.
Apr 18, 2017 | Kitchen Ranges
How do i rewire c15 socket for hot condition 6a line
Black wire to the brass screw
white to the silver
green wire to the ground
Jun 21, 2014 | Earlex LMB150 Steam Master Wallpaper...
Would like to rewire Astak CM-918 camera due to missing hardware
Red and black, are power; white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Nov 26, 2013 | Astak Home Security
Fan will not work unless wall switch is on
A ceiling fan can be wired in different ways.I prefer to connect only the lights to the wall switch,and the fan to the hot,so the fan can be used when the lights are turned off.You will need to locate the circuit to the fan and turn off the breaker.Remove the cover at the ceiling to access the wiring.The fan wiring is usually labeled,but I believe the light wire is blue,the fan wire is black,and the neutral is white.The light wire and fan wire are probably both connected to the same feed.You will need to rewire the fan to the hot(black) house wire.The light wire is fed from the wire after the wall switch-leave this as is if the lights turned on/off with the wall switch.After the rewire,turn the breaker on before replacing the cover,and verify everything is how you want it before replacing the cover.I usually remove the light chain to keep people from using the chain instead of the wall switch.
Jul 07, 2012 | Dryers
I took the plug off the dryer from the back to the wall , the 120/240 plug and dont know how to rewire it
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
I am rewiring the dash and I had to remove the connector that plugs into the back of the dash and I hard wired instead, the wires aren't matching up and I need a schematic to see where the wires go.
I AM WIREING PROBLEMS ALSO HAVING I KEEP BLOWING FUSE NUMBER 10 IS THIS WHY YOU ARE REWIRING THE DASH FROM SHORTING PROBLEMS AND BLOWING FUSES .I WAS WONDERING IF THE ELECTRICAL IS A PROBLEM IN THESE CARS
Oct 11, 2009 | 1998 Buick Century
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
Jun 04, 2009 | Lorex SG6153 / Weather Resistant Mini...
Trying to wire up a dt125r about 96 with wires riped out just for off road use
i have the same trouble spent 2 days trying to rewire it with no luck in all the wires im only getting a max of 0.4v
Apr 19, 2009 | 2000 Yamaha DT 125 R
Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision Logo
1,321 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
