Question about InFocus LP 600 Multimedia Projector
Lamp did not strike
What does this mean? cant get a picture as the message shows on the lcd screen.
  • 36 Answers
You have problem whit the lamp. you should replace the lamp.
Posted on Jun 18, 2010
Why projector takes time whe it is started
Depends entirely on what you mean by "takes time". These projectors require a few minutes to reach full brightness, and many models even activate an LCD shutter to black out the image until the lamp has reached reasonable brightness.
If you mean it takes several minutes to produce any picture at all, it may just be time to replace the lamp, as it may not be striking (starting the lamp) correctly due to a fault in the lamp starter circuit or the lamp itself. In the absence of a detailed fault description, my best guess is that it's most probably a tired lamp :o)
Apr 07, 2014 | Philips bSure SV1 Multimedia Projector
Getting a bulb did not strike message... any ideas?
If the lamp is good, then it was installed you may have pushed the lamp connection inside the lamp housing out of place so there is no connection being made.
Jan 31, 2011 | InFocus LP540 LCD Projector
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Ibm t23 screen goes blank in a second after a wake up. cant see screen for more than a second.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 02, 2009 | IBM ThinkPad T23 2647 Notebook
Compaq notebook monitor no longer shows pictures . Left screen for a few minutes and when I returned to the room, the screen was showing snow only. Rebooted and the screen has never returned a picture.
You could have a faulty LCD screen or a faulty video cable or conector. Try reseating the video cable or connector first.
Then
To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Jun 13, 2009 | HP Compaq Presario v3000z Notebook
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5630 Notebook
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP 600 Multimedia Projector Logo
141 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
